The Great How-To Modification Index!
zionzr2
Post by zionzr2 »
THE GREAT HOW-TO MODIFICATION INDEX!This will be an index of all modifications and their HOW-TO’s!This page will have direct links to these how to topics no matter where they may reside on these forums. The list will be arranged alphabetically by item being modified! This page may be changing often as the list grows so please check back often. Please do NOT reply to this topic, but if you have, know of, or see a HOW-TO, Please PM (Private-Message) me the thread and I’ll add the link to this list. Moderators please keep this as a Sticky.THANK YOU! Adding +12V socket to 2005 Center Console Rear Console +12V Power Outlet on all the time A/C Insulation for even faster cold air! Installing a AHL & DRL Overide Switch and Update to include the '09 Cold-Air-Intake install on BASE Vibe - Injen Cargo Area Carpet Solid Cargo Cover Another Solid Cargo Cover Catalytic Converter Replacement Changing the Clutch Dashboard Removal De-Badge Your Vibe (Remove the dealer tag) Ground Wire Upgrade Fog-Lamp Switch Rewire the way YOU want it. and NOW W/ Pics Fog Bulb Conversion 9005 instead of 9006 Heated Seats Horn Replacement Auto-Dimming Rearview Mirror Outside Mirror Disassembly for Turns, Heat, etc. Pet Barrier Horn Beeps on Keyless Entry Remote lock/unlock Retained Accessory Power for Power Windows Disable Reverse Beep and Replace with LED (GT models). Roof Rail Removal and Installation. or This one Seatbelt Chime Disable '05+ Model Years Seat Track Extension Spring Lowering Front Sway Bar Installation Tranny Cooler Interior Bike Mount Shark Fin Antenna DIY Cabin Filter Furnace Filter Replacement How to close sunroof without having to push button twice! FatMat Install License Plated LED Lights Aftermarket Head Unit Install Armrest Retrograde! Low armrest to Tall armrest. Third Brake Light Overlay Kill All Warning Beeps Adding Power Windows to non-Power-Package Front Facia R/I How To change blower motor and blower motor resistor Alternator Removal/Install PDF Foglight Adjustment Window Clunk Fix '09+ OEM Foglight Install NEW!! LED CHMSL NEW!!-------------------Disclaimer: All modifications are done at-your-own-risk. GenVibe, the moderators, myself, or the modification creators take no responsibility or provide any warranty or guarantee for changing your vehicle in any matter. Also be advised that some modifications will not be warranted by your dealer either. Again MODIFY AT YOUR OWN RISK.Updated 9:20PM CST 2/6/2010
KNINE
Re: The Great How-To Modification Index! (zionzr2)
Post by KNINE »
zionzr2
Post by zionzr2 »
^Bump^
keithvibe
Re: (zionzr2)
Post by keithvibe »
bump for all the noobs asking what seems like the same questions, with out searching
bull77
Post by bull77 »
B U M P thanks Bill for the updates
Vaggeto
Post by Vaggeto »
Bumping this. Although I think the links will need to be fixed.
Couldn't find it with search so manually went down the pages until I found it!
2003 Pontiac Vibe. AWD, Shadow, Monotone. Moons & Tunes. 16" Konig Zero-In wheels. (My Garage)
zionzr2
Post by zionzr2 »
I think I need someone to take this over....
I cant seem to properly edit the original list since the migration and I'm not visiting this site often enough to give it the attention it deserves.
Same goes for the Maint. Index page I created so long ago.
mrbravo2000
Post by mrbravo2000 »
BUMP, awesome thread.
canadave
Post by canadave »
mrbravo2000 wrote:BUMP, awesome thread.
It should be a sticky, if it isn't already.
2009 base Vibe, silver"
canadave wrote: It should be a sticky, if it isn't already.
It already is. viewtopic.php?t=38628" onclick="window.open(this.href);return false;
canadave
Post by canadave »
Cool. Well there ya go :)
ctgottapee
Post by ctgottapee »
Unfortunately all the links are dead, maybe using an old format...
jayoldschool
Post by jayoldschool »
I wished they worked! I could really use this one:
Searching those terms only comes up with this thread!
treesleavedents
Post by treesleavedents »
mods can we please get these links fixed?
jayoldschool
+1
Please, repair those links!
UPDATED URLS
  1. Adding +12V socket to 2005 Center Console viewtopic.php?t=10792 (was 13711)
  2. Rear Console +12V Power Outlet on all the time viewtopic.php?t=5078 (was 6403)
  3. A/C Insulation for even faster cold air! viewtopic.php?t=3830 (was 4914)
  4. Installing a AHL & DRL Overide Switch and Update to include the '09 viewtopic.php?t=6819 and viewtopic.php?t=28390 (was 8598,and 35116),
  5. Cold-Air-Intake install on BASE Vibe - Injen viewtopic.php?t=976 (was 1281)
  6. Cargo Area Carpet viewtopic.php?t=12498 (was 15734)
  7. [Solid Cargo Cover viewtopic.php?t=15662 (was 19612)
  8. Another Solid Cargo Cover viewtopic.php?t=16027 (was 26943)
  9. Catalytic Converter Replacement viewtopic.php?t=17587 (was 22020)
  10. Changing the Clutch viewtopic.php?t=17517 (was 21943)
  11. Dashboard Removal viewtopic.php?t=7912 (was 9977)
  12. De-Badge Your Vibe (Remove the dealer tag) viewtopic.php?t=12369 (was 15574)
  13. Ground Wire Upgrade viewtopic.php?t=15609 and viewtopic.php?t=8010 (was 19541)
  14. Fog-Lamp Switch Rewire the way YOU want it.ÿandÿNOW W/ Pics viewtopic.php?t=9844 and viewtopic.php?t=25798 (was 12376 and 32111)
  15. Fog Bulb Conversion 9005 instead of 9006 viewtopic.php?t=20094 (was 25124)
  16. Heated Seats viewtopic.php?t=15673 (was 19626)
  17. Horn Replacement USELESS X , viewtopic.php?t=2028 (was 2656)
  18. Auto-Dimming Rearview Mirror viewtopic.php?t=6136 (was 7735)
  19. "Outside Mirror Disassembly for Turns, Heat, etc." viewtopic.php?t=15103 (was 18927)
  20. Pet Barrier viewtopic.php?t=5789 (was 7302)
  21. Horn Beeps on Keyless Entry Remote lock/unlock (custom kits no longer available) X , viewtopic.php?t=16535 (was 20692)
  22. Retained Accessory Power for Power Windows viewtopic.php?t=13461 (was 16904)
  23. Disable Reverse Beep and Replace with LED (GT models). viewtopic.php?t=17165 (was 21480)
  24. Roof Rail Removal and Installation viewtopic.php?t=9134 (was 11484)
  25. Seatbelt Chime Disable '05+ Model Years viewtopic.php?t=14893 (was 18678)
  26. Seat Track Extension viewtopic.php?t=20770 (was 25988)
  27. Spring Lowering possible bad link to MO X , viewtopic.php?t=3834 (was 4918)
  28. Front Sway Bar Installation viewtopic.php?t=2888 (was 3790)
  29. Tranny Cooler viewtopic.php?t=16730 (was 23452)
  30. Interior Bike Mount linked content no longer available X , viewtopic.php?t=20218 (was 28162)
  31. Shark Fin Antenna viewtopic.php?t=22656 (was 28332)
  32. DIY Cabin Filter Furnace Filter Replacement viewtopic.php?t=20089 (was 25114)
  33. How to close sunroof without having to push button twice! viewtopic.php?t=7209 (was 9101)
  34. FatMat Install missing pics X , viewtopic.php?t=22728 (was 28424)
  35. License Plated LED Lights viewtopic.php?t=38000 (was 30169)
  36. Aftermarket Head Unit Install missing pics X , viewtopic.php?t=30378 (was 30794)
  37. Armrest Retrograde! Low armrest to Tall armrest. viewtopic.php?t=25396 (was 31630)
  38. Third Brake Light Overlay viewtopic.php?t=25544 (was 31801)
  39. Kill All Warning Beeps viewtopic.php?t=25922 (was 32254)
  40. Adding Power Windows to non-Power-Package viewtopic.php?t=26170 (was 32536)
  41. Front Facia R/I viewtopic.php?t=9959 (was 12551)
  42. How To change blower motor and blower motor resistor viewtopic.php?t=29211 (was 36099)
  43. Alternator Removal/Install PDF viewtopic.php?t=23299 (was 29114)
  44. Foglight Adjustment viewtopic.php?t=26143 (was 23672)
  45. Window Clunk Fix viewtopic.php?t=35798 (was 24086)
  46. '09+ OEM Foglight Install NEW!! viewtopic.php?t=30761 (was 37906)
  47. LED CHMSLÿNEW!! viewtopic.php?t=38196 (was 40176)
Unfortunately, some of these threads were by members who used external image hosting sites, and as they lost their vibe enthusiasm, they stopped hosting their images for us. Some of these I found are marked with an X. These still tend to provide a narrative, and hopefully, if you follow one of these to do a mod, you'll take and post replacement pictures. ragingfish's horn replacement tutorial was as I marked it, useless, because the thread basically says see this PDF which is no longer available, but i figured it best to leave the item in the list with the updated thread link, even though it really is as marked
The "(was #####)" at the end of each identifies the thread number when genvibe used zeroforum software. An increasijng thread number was assigned each time a new thread was created, and provides a chronological order to when the thread was created. It doesn't identify when the thread was last updated, just created. For various reasons, some threads get deleted. It seems that when genvibe was converted to phpBB, the existing threads were renumbered in order, preserving the chronological nature of the thread numbers, but there were no empty placeholders for previously deleted zeroforum threads.
Finding some of these was more difficult due to the common words to search for, and using the chronological thread numebrs helped identify exactly which thread was originally lionked, given, for example the large number of threads about power windows and DRLs.
The internet archive web.archive.org was useful for a number of threads, looking up the old URL there to see the date, originator, and creation date of the original URL, but it seems they stopped archiving genvibe at some point
Thank you so much Joatmon!
Consider making this a new thread, and put it up as a sticky because a lot of people will not scroll down to this post. Of course you would credit to the original author: zionzr2.
