I have a howto up on my blog for disabling the reverse beep of a 2003 Matrix and replacing it with and LED lamp.Lots of pictures, all 800x600, and steps for the process. Sorry, I couldn't find this mod anywhere else on this forum, so I started a new thread.Here's the link.Let me know if anyone has any questions! Feel free to leave a comment here and on the blog!
Very cool. I actually wrote up a how-to on matrixowners a a year or so ago. Yours is much more complete though with better pics. I've done this mod on my Matrix and Corolla. On the Corolla, I installed the LED in the top-left corner of the shifter base cover. On the Matrix, I installed it in the same place as yours, but your install is a lot cleaner.
you say its a 6 speed automatic but have a picture of a manual on the site. so I take it this is a manual only item? cause mine doesn't beep in reverse.
Quote, originally posted by scherry2 »you say its a 6 speed automatic but have a picture of a manual on the site. so I take it this is a manual only item? cause mine doesn't beep in reverse.Jeez, that was a silly error! It's corrected now.
Quote, originally posted by scherry2 »you say its a 6 speed automatic but have a picture of a manual on the site. so I take it this is a manual only item? cause mine doesn't beep in reverse.the reverse beep is only in the 6 spd 2zz engines. i believe they did it because the reverse and first gear are next to each other.
I just did this mod today, and the check engine light came on. Is this normal or is this a coinsidence? I cut the correct wire, and the beep beep has stopped.EDIT:The check engine light went away after I drove it again. I forgot that I drove to the store without my gauges, I'm guessing that was it.
Quote, originally posted by dallarosaj »The link does not work. Can you e-mail me on how to do it.I just checked the link and it's still working. Maybe the page didn't load for you. Try again.
