Help needed: 2009 Vibe 12V Aux power outlet
tonycheung
Post by tonycheung »
Hi,
I saw a post of wiring the relay so the 12V aux power is always on however it was for the previous generation.
Is there anyone know where is the relay for 2009+ vibe?
Thank you.
Tony
strangerxp
Re: Help needed: 2009 Vibe 12V Aux power outlet
Post by strangerxp »
Vibe 09 pwr dist 1.pdf
(69.53 KiB) Downloaded 390 times
Hello Tony, take a look on the attachments, hope it helps,
Regards, stranger
Vibe 09 pwr dist 3.pdf
(77.71 KiB) Downloaded 338 times
Vibe 09 pwr dist 2.pdf
(85.58 KiB) Downloaded 263 times
strangerxp
Vibe 09 pwr dist 4.pdf
(75.41 KiB) Downloaded 240 times
There is the last two.
Vibe 09 pwr dist 5.pdf
(74.3 KiB) Downloaded 223 times
beemerphile1
Post by beemerphile1 »
You could disconnect the power wire at the receptacle and run a new (fused) power wire to it.
I chose to keep the stock receptacle switched as it was. I did add 3 always on receptacles and a USB power port. I installed them in the slot below the radio.
I keep a rechargeable trouble light plugged into the switched receptacle. On occasion I have a GPS, satellite radio, radar detector, and cell phone plugged into the added receptacles.
tonycheung
Hi strangerxp,
Thank you for the schematic and I will study it when possible.
cheers,
Tony
In the diagrams that strangerxp posted, 5 shows the lighter (12V outlet). It goes directly to the CIG fuse, and from there to point Q in diagram 3. It works backwards through the accessory relay, which is controlled by the ignition switch. Theoretically you could replace that accessory relay with a jumper wire, but then your radio, amp, and outside mirrors would always have power. Years ago I had a car where the radio wasn't not switched by the key, I recommend against that.
On the 03-08's the cig lighter is wired pretty much the same as in these diagrams. the 03-04's had a second 12V power outlet between the seats, and it is easy to add it to the 05-08's since the wiring is all there. This second outlet is controlled by it's own individual relay, and that 's the one to replace with a jumper to leave the outlet powered on all the time. There is no direct equivalent for the 09-10's, so if you want the lighter outlet to be on all the time, your pretty much need to do as beemerphile1 says, just run a new constant 12V to the lighter.
