Does My OEM Radio Have a Security Anti-theft Code?
Reaccion
Post by Reaccion »
Hello Guys! My sister bought a 2004 Vibe three days after I showed her mine 2003 LOL. I noticed that her OEM radio says Anti-Theft under the red blinking light on the radio. My 2003 Vibe has everything that my sister's has except that mine does not say anything about security codes. My radio light still blinks when the Vibe is turned off. It is just that it does not have the Anti-Theft letterings on it. My question is, would my OEM radio need a security/anti-theft code if I ever unplugged the positive battery terminal?? Thanks!
03 04 05 06 07 08 2003 2004 2005 5006 2007 2008
jake75
Re: Does My OEM Radio Have a Security Anti-theft Code?
Post by jake75 »
From what I have read here that red blinking light is just a red blinking light. Just like sometimes a cigar is just a cigar.
No issues when we had the battery changed in my son's 06. Just kind of like the alarm signs people have outside their house. Maybe you have one, maybe not.
Reaccion
Post by Reaccion »
jake75 wrote:From what I have read here that red blinking light is just a red blinking light. Just like sometimes a cigar is just a cigar.
I was trying to find the code in the owner manual and nothing.
Reaccion
Post by Reaccion »
trb wrote:No issues when we had the battery changed in my son's 06. Just kind of like the alarm signs people have outside their house. Maybe you have one, maybe not.
Okay, so when you disconnected your battery, did not the radio lock up and asked you for a security code? I just wanted to find out the easy way instead of the hard one.
Neither your Vibe nor your sister's Vibe have an actual theftlock radio.
Theftlock radios used by GM require a data bus in the car, where the radio is connected to the car's computer and other things. SInce the Vibe is mostly Toyota, there is no GM data bus in the car. GM uses the same basic radio in other cars, enabling the theftlock by changing the radio's programming, but they used a different program for the ones that go in Vibes, one that does not require the data bus.
So, we get a radio that has a red LED that blinks when the car is off. Looks like a theftlock radio, but really no secret that it is just a pretend security device
If you were to buy another OEM radio for your Vibe, be sure it came out of a Vibe or Matrix, because there are GM radios out there that look the same but will not work in a VIbe.
If you were to remove the radio, or disconnect the battery for a year, the only effect on the radio when you hook it back up is that you'll need to set the clock.
Reaccion
Post by Reaccion »
joatmon wrote:Neither your Vibe nor your sister's Vibe have an actual theftlock radio.
Wow Joatmon! Thank you very much for such of explicit information. I really appreciate it. I was really afraid to disconnect the battery on my Vibe. Thanks!!
Vibeology
Post by Vibeology »
joatmon wrote: ↑Sat Nov 10, 2012 6:09 am Neither your Vibe nor your sister's Vibe have an actual theftlock radio.
Is the quoted info accurate?
The following is straight from my 2007 owner's manual:
"A red light blinks while the engine is off to indicate the radio is protected. It will not operate if it is installed in a different vehicle."
Vibeology wrote: ↑Fri Sep 26, 2025 4:51 pm
I see that in the 07 manual, and while I think the quoted info applies to your 07, I can't testify that it does.
I know first hand that it does apply to 03s, 04s, and 05s. Also, from trb's post above, it applies to 06s.
Nobody has reported any problems with a radio being theftlocked on an 07 in the 18 years since they came out. I would be surprised if your 07 had the data bus infrastructure required to implement GM's theftlock, as that seems like a fairly significant change that nobody here has ever reported before. Also, I often use car-part.com which implements an interoperability reference in their junkyard inventory system, and when I look for 03 radios, the site gives me radios from 03-08
so, while I assume your 07 does not have theftlock, and that the user's manual is wrong, I can't personally guarantee. Maybe some 07/08 owners will chime in with their experiences
SSizler
Post by SSizler »
I can confirm that the radios do not need a code if you get a replacement that came from a Vibe.
I have changed from single CD to 6CD changer also with no problems.
This is on 03, 05 and 06 Vibes.
05 Base/ Lava Red/ Daughters
2 for parts
Vibeology
Post by Vibeology »
I replaced the head unit with another of the same part number.
No code needed (2007 Vibe).
cc333
Post by cc333 »
I installed a radio that looks very much like the Vibe's, except it has a cassette player (I had wanted one in there since we bought it new in 2006). It works 100% fine and looks exactly like the Vibe's stock unit, except it has the cassette player I'd always wanted :)
I don't know what car it came from, but it likely wasn't another Vibe (as far as I know, no Gen 1 Vibes had a cassette option; I know for certain that the '06 didn't, however). Based on what information I could find, it is probably from a 2000-2002 Bonneville.
So apparently 2000-2002 Bonneville and Gen 1 Vibe radios are interchangeable to a degree?
c
The 03 (and possibly 04) Matrix had an optional radio with cassette deck. I have bought and installed them in three Vibe/Matrix, to support one of those tape to phono plug adapters for playing music on the phone through the car radio. Was never an option on Vibes, but fully interchangeable.
My understanding was that comparable GM year radios that appear to be identical to the vibe radio had a dependency on the GM data bus that was not implemented in the Vibe because is is primarily a Toyota. So maybe you got one from an 03 matrix, or maybe the GM data bus wasn't fully implemented on some other models
cc333
Post by cc333 »
joatmon wrote: ↑Fri Jun 19, 2026 1:24 pm The 03 (and possibly 04) Matrix had an optional radio with cassette deck. I have bought and installed them in three Vibe/Matrix, to support one of those tape to phono plug adapters for playing music on the phone through the car radio. Was never an option on Vibes, but fully interchangeable.
I didn't know the '03-'04 Matrix could be optioned with the Delco AM/FM/CD/Cassette. Given that it was completely plug & play and works 100% perfectly, that must be where mine came from.
In support of this, I removed it to service the tape deck recently (and to refresh it with new buttons and face), and I think I remember seeing an '02 date code (I have to remove it again to service the CD player, so I'll take another look).
It really is weird that GM didn't offer it on the Vibe, especially if Toyota did (until they switched to their own radio with the noninterchangeable bezel anyway; did that Toyota radio have a cassette option, or were they all CD only, as in the Vibe?
It was one of the few things I didn't like about it when we bought it (I had a large collection of tapes I wanted to listen to while we were driving, but I couldn't, so I moved to CDs. Had I known at the time about '03-04' Matrixes (Matrices?) having an interchangeable radio with the cassette option, I would've looked into getting one back then (I finally found the one I got years later, long after I gave up on tapes).
c
