Scan Gauge setting, whats your compensation ???
yyamad1
Post by yyamad1 »
Ive been using the Scan gauge in my vibe for couple of years, just out of curiosity, I was wondering what peoples compensations are from the default. It shows you the % when you do the fill up and put in the actual pump gallons you put in... I have to check my scan gauge for that tomorrow.. and i will post it. I normally get 30-31 mpg per tank in Chicago IL, summer a little more. I have gotten 38-39mpg on easy highway trips but never gotten that for the entire tank. So I think my setting is pretty accurate, its always within few tenths of a gallon...and I drive a 04 Vibe 5 speed base.
Old Tele man
Post by Old Tele man »
...I'm using a +12.3% (fuel gallons) calibration factor on my SGII in my 2009 1.8L 4A base Vibe....but, be aware that number changes when they switch from winter to summer gasoline mixes.
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
beemerphile1
Post by beemerphile1 »
I've never used the SGII in my Vibe. I have used it for a few years in my E150 with a 35 gallon fuel tank.I've noticed that the offset changes every tank by a large amount. I don't know if I am being ripped by the gas stations or it is something else. The variance will be much less noticeable with the Vibe due to a smaller tank.
yyamad1
Re: (Old Tele man)
Post by yyamad1 »
Thanks for the post mine was 13.2%, so perhaps its a little less efficient than your car lol I hope my new mods will make a little difference
Re: Scan Gauge setting, whats your compensation ??? (yyamad1)
Not sure what mine is at the moment. When I first got it close to a year ago, I set everything up initially and haven't touched it since then. I have noticed my calculated MPG is about 3-4 MPG higher than actual, so I'll have to adjust it and get it closer to reality. I'll do this soon as I'll start driving it a bit more with nicer weather
2014 Silverado, 2004 Vibe GT
