Scan Gauge setting, whats your compensation ???
yyamad1
Post by yyamad1 »
Ive been using the Scan gauge in my vibe for couple of years, just out of curiosity, I was wondering what peoples compensations are from the default. It shows you the % when you do the fill up and put in the actual pump gallons you put in... I have to check my scan gauge for that tomorrow.. and i will post it. I normally get 30-31 mpg per tank in Chicago IL, summer a little more. I have gotten 38-39mpg on easy highway trips but never gotten that for the entire tank. So I think my setting is pretty accurate, its always within few tenths of a gallon...and I drive a 04 Vibe 5 speed base.
Old Tele man
Post by Old Tele man »
...I'm using a +12.3% (fuel gallons) calibration factor on my SGII in my 2009 1.8L 4A base Vibe....but, be aware that number changes when they switch from winter to summer gasoline mixes.
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
beemerphile1
Post by beemerphile1 »
I've never used the SGII in my Vibe. I have used it for a few years in my E150 with a 35 gallon fuel tank.I've noticed that the offset changes every tank by a large amount. I don't know if I am being ripped by the gas stations or it is something else. The variance will be much less noticeable with the Vibe due to a smaller tank.
yyamad1
Re: (Old Tele man)
Post by yyamad1 »
Thanks for the post mine was 13.2%, so perhaps its a little less efficient than your car lol I hope my new mods will make a little difference
Re: Scan Gauge setting, whats your compensation ??? (yyamad1)
Not sure what mine is at the moment. When I first got it close to a year ago, I set everything up initially and haven't touched it since then. I have noticed my calculated MPG is about 3-4 MPG higher than actual, so I'll have to adjust it and get it closer to reality. I'll do this soon as I'll start driving it a bit more with nicer weather
