I doubt this thing really works.Most (almost all) of light are running with programmable time and some with sensors (kind of magnet under the ground to detect metallic mass or simply movement sensors). I cannot see how this thing can tell a time to chage the light right away instead of at the end of his countdown.But, I know here, in Quebec city, the fire depatment implemented a new system to have the light turning green when the fire truck is coming. This system is very complex and worh with FM signaling and GPS. And all intersection have to be updated with the FM receptor to work properly.
apparently they do work, and that is why they either are pushing or just passed a law to make them illegal for non-emergency vehicles in Maryland. if a lo of people had them it would make regulated traffic flow degrade into total chaos, and it's bad enough already.
Quote, originally posted by Sub-Vibe-R »I doubt this thing really works.Most (almost all) of light are running with programmable time and some with sensors (kind of magnet under the ground to detect metallic mass or simply movement sensors). I cannot see how this thing can tell a time to chage the light right away instead of at the end of his countdown.But, I know here, in Quebec city, the fire depatment implemented a new system to have the light turning green when the fire truck is coming. This system is very complex and worh with FM signaling and GPS. And all intersection have to be updated with the FM receptor to work properly.I think these are meant for emergency vehicles so it might work just like the fire department in Quebec that you mention.
The device is real but it is a felony for a private citizen to own one. Also, the device only works on signals designed to use them. It does not work on regular signals.More info: http://caranddriver.com/articl...ber=1
Quote, originally posted by NovaResource2 »The device is real but it is a felony for a private citizen to own one. Also, the device only works on signals designed to use them. It does not work on regular signals.More info: http://caranddriver.com/articl...ber=1 You are bang on! We have them installed on our trucks. We have four intersections that are set up to react to this system. Get caught using these on a private vehicle and expect very heavy fines!
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
Quote, originally posted by Sub-Vibe-R »I doubt this thing really works.Most (almost all) of light are running with programmable time and some with sensors (kind of magnet under the ground to detect metallic mass or simply movement sensors). I cannot see how this thing can tell a time to chage the light right away instead of at the end of his countdown.But, I know here, in Quebec city, the fire depatment implemented a new system to have the light turning green when the fire truck is coming. This system is very complex and worh with FM signaling and GPS. And all intersection have to be updated with the FM receptor to work properly. It works on the strobe effect not a radio signal. The radio signal is not used because of the effects of weather, proximity of other signals etc..
Quote, originally posted by engine1 » It works on the strobe effect not a radio signal. The radio signal is not used because of the effects of weather, proximity of other signals etc.. The one in Quebec city really work with FM signal. They choose this way over the infra-red signal.It can have many way to do this, infra-red, FM, strobe effect....
I guess anything is possilble out there eh?? Jean-Paul
