Need this device!!!!
wicked1981
Post by wicked1981 »
Well Has anyone purchased this or heard about this? I think it would be cool to have it.http://www.mirtworld.com/mirt-...t.asp
2006 Pontiac G6 GTP3.9L V-6 240hp and 241 lb-ft or torque18" Aluminum, five-spoke, flangeless200 Watt, 8 speaker Monsoon sysChrome dual exhaust tipsLiquid Silver MetallicBorla Custom ExhaustDr. Speed Cold Air Intake
Sub-Vibe-R
Re: Need this device!!!! (silverawd26)
Post by Sub-Vibe-R »
I doubt this thing really works.Most (almost all) of light are running with programmable time and some with sensors (kind of magnet under the ground to detect metallic mass or simply movement sensors). I cannot see how this thing can tell a time to chage the light right away instead of at the end of his countdown.But, I know here, in Quebec city, the fire depatment implemented a new system to have the light turning green when the fire truck is coming. This system is very complex and worh with FM signaling and GPS. And all intersection have to be updated with the FM receptor to work properly.
Re: Need this device!!!! (Sub-Vibe-R)
apparently they do work, and that is why they either are pushing or just passed a law to make them illegal for non-emergency vehicles in Maryland. if a lo of people had them it would make regulated traffic flow degrade into total chaos, and it's bad enough already.
wicked1981
Quote, originally posted by Sub-Vibe-R »I doubt this thing really works.Most (almost all) of light are running with programmable time and some with sensors (kind of magnet under the ground to detect metallic mass or simply movement sensors). I cannot see how this thing can tell a time to chage the light right away instead of at the end of his countdown.But, I know here, in Quebec city, the fire depatment implemented a new system to have the light turning green when the fire truck is coming. This system is very complex and worh with FM signaling and GPS. And all intersection have to be updated with the FM receptor to work properly.I think these are meant for emergency vehicles so it might work just like the fire department in Quebec that you mention.
Fialchar
Re: Need this device!!!! (wicked1981)
Post by Fialchar »
Although I don't know anything about it, the cops here have a device to change red lights to green as well.
NovaResource2
Re: Need this device!!!! (Fialchar)
Post by NovaResource2 »
The device is real but it is a felony for a private citizen to own one. Also, the device only works on signals designed to use them. It does not work on regular signals.More info: http://caranddriver.com/articl...ber=1
engine1
Re: Need this device!!!! (NovaResource2)
Post by engine1 »
Quote, originally posted by NovaResource2 »The device is real but it is a felony for a private citizen to own one. Also, the device only works on signals designed to use them. It does not work on regular signals.More info: http://caranddriver.com/articl...ber=1 You are bang on! We have them installed on our trucks. We have four intersections that are set up to react to this system. Get caught using these on a private vehicle and expect very heavy fines!
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
engine1
Post by engine1 »
Quote, originally posted by Sub-Vibe-R »I doubt this thing really works.Most (almost all) of light are running with programmable time and some with sensors (kind of magnet under the ground to detect metallic mass or simply movement sensors). I cannot see how this thing can tell a time to chage the light right away instead of at the end of his countdown.But, I know here, in Quebec city, the fire depatment implemented a new system to have the light turning green when the fire truck is coming. This system is very complex and worh with FM signaling and GPS. And all intersection have to be updated with the FM receptor to work properly. It works on the strobe effect not a radio signal. The radio signal is not used because of the effects of weather, proximity of other signals etc..
Sub-Vibe-R
Re: Need this device!!!! (engine1)
Quote, originally posted by engine1 » It works on the strobe effect not a radio signal. The radio signal is not used because of the effects of weather, proximity of other signals etc.. The one in Quebec city really work with FM signal. They choose this way over the infra-red signal.It can have many way to do this, infra-red, FM, strobe effect....
engine1
Post by engine1 »
I guess anything is possilble out there eh?? Jean-Paul
