It doesn't work! Do'h!!! Cause I forgot to put the fuse back in the fuse holder under the hood!! Which, btw, you can't tell except for the holder mounted on the firewall.
- fuse.jpg (258.82 KiB) Viewed 11152 times
Hindsight for me, but something to consider for others looking to upgrade or install one of these gems, I would mount the amp to the box in the available space in the compartment on top. I'm using a Taramps 400watt Monoblock because of the size (Class D) and best bang for the buck - it would fit perfectly there, but instead, I mounted it under the rear seat (Again, I do NOT recommend mounting anything that requires drilling under the rear seats - gas tank!)
- storage-compartment-future-amp-install.jpg (221.54 KiB) Viewed 11152 times
How does it sound?! Well, I haven't spent the time to tune it, yet, HOWEVER, I am thrilled with the performance out of all the budget components (Kicker being a budget component is subjective). What's next, you might be wondering? The headunit I purchased has a sub out, but it's nothing more than left channel out with zero bass controls in the head unit. I purchased a budget bass knob with frequency adjustment and will use proper L/R outs. I'm considering installing it through the coin holder under the parking brake. Stay tuned!
