This is the DIY index to replace zionzr2's "The Great How-To Maintenance Index!" His index was a fantastic tool until software changes damaged the links and wiped out the pictures in many threads. Zionzr2 deserves all the recognition for this idea and the work he did.
Please, do not reply to this thread. PM me with the link of a how to that you wrote or found here or somewhere else. I will add it to the this index. Over time it will have lots of direct links to the various threads on this site and other sites as well.
Moderators, please keep it a sticky.
Thanks to zbyers many of the files are also available on Facebook: https://www.facebook.com/groups/Genvibe/files/
And thanks to mkowdley you can click here as well: viewtopic.php?f=28&t=46708
Fellow Vibers, recruit more members: viewtopic.php?f=11&t=26365&p=297852&hilit=Flyer#p297852
Here is an excellent overview of the Pontiac Vibe: viewtopic.php?f=11&t=40003
On the ToyotaNation forum you can find the analogous thread. Almost all of the how-to articles apply to our Vibes: http://www.toyotanation.com/forum/132-9 ... ticky.html
This Toyota Corolla site is excellent as well: https://www.paulstravelpictures.com/Art ... Guides.htm
And there is an expansive list of parts-numbers: http://www.toyotanation.com/forum/132-9 ... hread.html
If you are shopping for a Vibe it will be a used one. Here is a check list for used car buyers: download/file.php?id=3765
Check for open recalls using your VIN:
https://vinrcl.safercar.gov/vin/
https://my.gm.com/recalls
Find your Owner's Manual here: viewtopic.php?t=755
Exterior:
Touch-up paint chart: viewtopic.php?f=33&t=15802
Exterior light bulb replacement guide: viewtopic.php?t=5438
Gen 2: replace headlight bulbs: viewtopic.php?t=41889
Gen 2: replace license plate light: viewtopic.php?f=33&t=37001#p414673
Rewire the fog light switch: viewtopic.php?t=31518
Disable DLR: viewtopic.php?t=897
Fix loose window regulator bolts: http://forums.genvibe.com/files/importe ... owfix..doc
Fix worn door checks: viewtopic.php?f=11&t=47030
Bumper Cover Removal: viewtopic.php?f=28&t=44874#p509495
Replace door window surround: viewtopic.php?f=11&t=45951
Reattach loose Door Molding, Door Cladding: viewtopic.php?f=28&t=44681#p507900
Replace Rear Wiper Blade Inserts: viewtopic.php?t=6134#p62760
Remove the Roof Rack: https://www.youtube.com/watch?v=yNfR77ZVzOs&
Interior:
Remove seats and carpet: viewtopic.php?f=29&t=36163
How to remove dash panel, bezel: https://www.youtube.com/watch?v=ECHAoRYZXJY
Clear clogged drain tubes for the moon roof: viewtopic.php?f=17&t=44835
Replace the light bulb for the gear indicator on automatics: viewtopic.php?f=18&t=43746
and: https://www.youtube.com/watch?v=44UV_UF-_Wk
How to replace the clock spring  (Gen1):viewtopic.php?f=28&t=45702
how to remove center console, Gen2: viewtopic.php?f=29&t=45343
Replace blend door actuator: https://www.youtube.com/watch?v=gjEVPCi5JVU
Recirculation gear fix: viewtopic.php?t=23692
Fix window rattles (remove door panel): viewtopic.php?f=20&t=19269
Window clunks on the way down, door strap clearance: viewtopic.php?f=29&t=35798
Radio Lights: viewtopic.php?f=17&t=26889#p305136
Radio Upgrade, Sound Insulation: viewtopic.php?f=11&t=40421#p477811
Radio Knob in Gen2: viewtopic.php?f=11&t=34757
Pet Barrier: viewtopic.php?f=28&t=43345
and: viewtopic.php?f=28&t=5789&hilit=pet+barrier
Remove Blower Motor and Blower Motor Resistor: viewtopic.php?f=28&t=29211&hilit=change+cabin+filter
Change Cabin Air Filter, Pollen Filter: viewtopic.php?f=20&t=6135&p=62765&hilit ... ter#p62761
Lumbar Support: viewtopic.php?f=28&t=43419
Armrest: viewtopic.php?f=28&t=25396
Driver's Seat Raised: viewtopic.php?f=30&t=43476#p499779
Affix Cargo Mat so it won't slide: viewtopic.php?f=29&t=44221&hilit=nerdydaddyo
also: viewtopic.php?f=30&t=43476#p505263
Fix for loose Power Window Switch Bezel: viewtopic.php?f=28&t=36996&hilit=door+switch+bezel
How to tie down the hatch: viewtopic.php?f=33&t=45221
Suspension, Brakes, Steering:
Trouble with the lug nuts? viewtopic.php?f=20&t=45885#p517673
Front Brake Tutorial: viewtopic.php?f=26&t=24417
Video:
Part 1: https://www.youtube.com/watch?v=O1T50LZi8yc
Part 2: https://www.youtube.com/watch?v=uOjmEjSgUiw
Power steering return hose: viewtopic.php?f=20&t=45361
How to remove the steering wheel (part of clock spring replacement): viewtopic.php?f=28&t=45702
Front Sway bar removal and installation:  viewtopic.php?f=28&t=2888
Rear Drum Removal Tip: viewtopic.php?t=21087
Gen2 Rear Brake change: viewtopic.php?f=26&t=46368#p520797
2nd gen FWD parking brake adjustment: viewtopic.php?f=26&t=46371#p520808
Steering Column Assy: http://madstyle1972.com/Repair/50/200kq/w040001.pdf
Drive Train:
Starter relay location: viewtopic.php?f=17&t=46084
Persistent erratic idle issue: viewtopic.php?f=12&t=46175&sid=228d6b64 ... 5a#p519584
Replace belt tensioner and broken bolt: viewtopic.php?f=28&t=45824
Gen1 1zz oil dip stick: viewtopic.php?f=12&t=37406&p=437602&hil ... ck#p437602
1ZZ only: Replace timing chain tensioner: https://www.youtube.com/watch?v=ykC7ykTwbCg
2ZZ heads up! on timing chain tensioner: viewtopic.php?f=28&t=44901
2ZZ high idle with cable operated TB: http://www.lotustalk.com/forums/f25/thr ... dle-98214/
P0420, Replace Oxygen Sensors: viewtopic.php?f=20&t=43379
Catalytic converter Replacement: viewtopic.php?t=44508 and: viewtopic.php?t=17587
Catalytic Converter Replacement AWD: viewtopic.php?f=12&t=45854&sid=12710e2d ... cc#p517462
Compression test: viewtopic.php?f=12&t=43155
Check Valve Lash: https://www.youtube.com/watch?v=U526fHMofak
Replacement Valve Lifter Shims: download/file.php?id=2671
Mystery ticking noise (lifter noise?): viewtopic.php?f=11&t=45178#p512306
Servicing or replacing the VVT oil control valve: http://au.toyotaownersclub.com/forums/i ... sstrainers
ATF Transmission Fluid Change: viewtopic.php?t=40411
Manual Transmission Fluid Change, Gen1 GT: https://www.youtube.com/watch?v=Pol80ImsUTc
Fuel Filter Change: viewtopic.php?t=30013
Replace PCV valve, 2003-2008: viewtopic.php?f=12&t=35419
and: https://www.youtube.com/watch?v=E7j3s71VUsE
Replace PCV Valve on 2ZR-FE engine: http://www.youtube.com/watch?v=A4iKLYpOg4A
Add a PVC oil trap: viewtopic.php?f=28&t=45634#p515873
Intake manifold Gasket: viewtopic.php?f=20&t=33056#p475654
ISC and IACV: Idle Speed Control, Idle Air Control Valve, clean and replace gaskets (with pictures): viewtopic.php?f=17&t=36489
Drive by Wire reset: viewtopic.php?f=12&t=20191
Replace fuel pump video: https://youtu.be/1YvPYTgKAIs
Other:
Gas mileage drop: viewtopic.php?f=17&t=6088&#p65128
Disable TPMS: viewtopic.php?f=28&t=39913
Remote Start Installation: viewtopic.php?f=11&t=40426
Also: http://www.youtube.com/watch?v=TeuqGP3hgE0
Washer Pump Replacement: viewtopic.php?t=38090
Dash Cam: viewtopic.php?f=29&t=44688
Make room for a hydraulic jack: viewtopic.php?f=29&t=45026
