emergency brake light
smsteriti
Post by smsteriti »
I have a 2008 manual 5 speed Vibe. Does this model have a light that tells me that my emergency brake is set? is mine broken?
DarkSpork
Re: emergency brake light (smsteriti)
Post by DarkSpork »
Yes.
2003 Pontiac Vibe GT
smsteriti
Re: emergency brake light (DarkSpork)
Post by smsteriti »
Thank you, I've been finding that my brake has been engaged but no light telling me so. I didn't drive far before i realized it was on but now it's happened a few times and wanted to check before i took the time to bring it in to the shop.
DarkSpork
Post by DarkSpork »
I hope it doesn't cost you a lot to get it fixed in a shop. I'm so cheap if I couldn't figure out how to fix it I'd just deal with it. EDIT: Is your emergency brake pulled up all the way? My dummy light for the emergency brake does not illuminate until its about half way up.
smsteriti
Post by smsteriti »
no, the light does not come on at all. it still under warrenty so i hope it doesn't take all day to get fixed
DarkSpork
Post by DarkSpork »
It shouldn't.
Does the light come on when the key is turned to start? If it does come on, you just have a faulty switch on the brake lever or a bad connection. If it doesn't come on, thats a much bigger problem - could even be the gauge cluster itself then.
Image Image
zionzr2
Post by zionzr2 »
mine comes on just at first click as you are pulling it up.
