Thank you, I've been finding that my brake has been engaged but no light telling me so. I didn't drive far before i realized it was on but now it's happened a few times and wanted to check before i took the time to bring it in to the shop.
I hope it doesn't cost you a lot to get it fixed in a shop. I'm so cheap if I couldn't figure out how to fix it I'd just deal with it. EDIT: Is your emergency brake pulled up all the way? My dummy light for the emergency brake does not illuminate until its about half way up.
Does the light come on when the key is turned to start? If it does come on, you just have a faulty switch on the brake lever or a bad connection. If it doesn't come on, thats a much bigger problem - could even be the gauge cluster itself then.
