Popping noise in 03' AWD Vibe...
pinkertonfloyd
Post by pinkertonfloyd »
Anyone else notice this, when taking off from dead stop, about 50% of the time I hear a "pop" from what seems like just behind the drivers seat...Ideas?
Re: Popping noise in 03' AWD Vibe... (pinkertonfloyd)
I haven't heard anything like that in my base 5 speed, and can't imagine what it might be. I have heard various sounds in this car, and I have a really hard time figuring out what direction the sound is really coming from. Helps to have someone else in the car who can move around to really pin down the location. Not saying the sound isn't where you said, just that I have been wrong a couple of times in this car.
SCTM
Re: Popping noise in 03' AWD Vibe... (joatmon)
Post by SCTM »
Never heard that on mine either Pinker.. Is this coming from the inside or outside (behind the driver's seat)Inside: could be something loose under rear seat on in trunk. Make sure your rear cargo flat panel is "lock"... but look if your mother-in-law is not sleeping in before. Outside: check for loose hubcap plastic retaining bolts or wheel bolts, may be rear brake needs adjustment or your AWD system.By the way, welcome to Genvibe on your first post. Let us know when you find something.
SCTM QUÉBEC Base 5spd Satellite, 20-35%back-tint, 3M film, HiddenHitch, Motegi Racing MR8, Orbit Remote Starter/5Doors, Winter GoodYear UltraGrip ice... and Lawnmower 310CCA battery !
SCTM
Re: Popping noise in 03' AWD Vibe... (SCTM)
Post by SCTM »
Check on "Handling, Suspension & Brakes, Subject: Encountering any brake-related noises?may be related...
Sounds like their might be a loose bolt somewhere...If a bolt is loose, as you take off, the initial jerk from the take off could cause whatever that bolt is holding down to jump, causing the popping noise.
