Rear door pannel installation?
JVonD
Post by JVonD »
Could you please tell me and others how to remove the window cranks on the vibes rear doors. Thanks!IM me at Yahoo please: jvond_tspThanks ~Jeff
Jahntassa
Post by Jahntassa »
Either a window crank removal tool, a flat headed screwdriver, pick, or small needle-nose pliers.. (If it doesn't just screw off, I have the power package, so i'm not sure. There's a little spring clip holding it on. Carefully push back on the door panel to reveal the space between the panel and the crank, pull, or push the spring off, and the crank will just come off.-IF- that's now they did it. On some fords you have to pull up on the crank, which has a cover over a T-20 type screw.
JVonD
Re: (Jahntassa)
Post by JVonD »
Yeah its un-powered. Thanks a lot!
ebslopp
Re: (JVonD)
Post by ebslopp »
Push the door panel in as far as you can around the crank, and take a look behind the crank arm. You will see a C shaped clip known as a "Jesus Clip" because when you take it off, you will say "Jesus!" and it will go flying. Anyways, you remove the clip and pull the handle off.
agbhyde
Re: (ebslopp)
Post by agbhyde »
LOL!!!!btw, nice rims OP!!! THey look just like mine!!!
scherry2
Re: (agbhyde)
Post by scherry2 »
this is the real tool to remove the clip but a small pocket screwdriver will work.
Re: (scherry2)
I've used a cloth, just pull it in between the door and handle. the cloth catches on one of the ends of the clip an pops it off the handle.
scherry2
Re: (joatmon)
Post by scherry2 »
Quote, originally posted by joatmon »I've used a cloth, just pull it in between the door and handle. the cloth catches on one of the ends of the clip an pops it off the handle. never thought of that. that is a good idea, and you don't go "jesus"
