i got an ebay bar and the bolt and nut that hold the end piece(black c on strut towers) the bar . well the endpiece has to tabs wit holes that go tab,bar,tab, with the bolt going thru all three then the nut.there is a lot of space between the tab and bar, should i just crank down on the nut and bolt and smash the pieces together so that they are tight.i doubt they are supposed to be loose and jiggly like that.
I left mine loose till I got it all the way onto the car then I cranked its tight so it was hard to move but still could move a couple millimeters back and forth then twisted the actual bar itself so that it was impossible to move up and down at all
