stb help
satur9
stb help
Post by satur9 »
i got an ebay bar and the bolt and nut that hold the end piece(black c on strut towers) the bar . well the endpiece has to tabs wit holes that go tab,bar,tab, with the bolt going thru all three then the nut.there is a lot of space between the tab and bar, should i just crank down on the nut and bolt and smash the pieces together so that they are tight.i doubt they are supposed to be loose and jiggly like that.
nismo
Re: stb help (satur9)
Post by nismo »
The stb should be tight. There should be zero movement. The tighter the better. Just don't strip the bolt. JMHO.Inder Singh
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
Smokin' Rubber
Re: stb help (TRD4reel)
Post by Smokin' Rubber »
I left mine loose till I got it all the way onto the car then I cranked its tight so it was hard to move but still could move a couple millimeters back and forth then twisted the actual bar itself so that it was impossible to move up and down at all
