2003 Vibe needed New wheel bearing at 38,000 km
nonstop
Post by nonstop »
My 2003 Vibe is dealer maintained to schedule and developed a front end noise that started @ 60 kph and faded away at 120 kph. Dealer diagnosed a bad front right wheel bearing and replaced the hub assembly containing same. OK now, but has anybody else had front end issues. The car is 15 months old and 2/3 through my Warranty. Hmm. Continental tires are hanging in OK and brake wear is very slight.
Raven
Re: 2003 Vibe needed New wheel bearing at 38,000 km (nonstop)
Post by Raven »
Has it been lowered or is it stock?
You might be the first here to lose a bearing. seems early for that though, , but at least it was covered under warranty.
Mavrik
Re: 2003 Vibe needed New wheel bearing at 38,000 km (joatmon)
Post by Mavrik »
Keep an eye on those conti tires though... those will start making a "bearing" noise when they get worn out.
nonstop
Re: 2003 Vibe needed New wheel bearing at 38,000 km (Mavrik)
Post by nonstop »
Actually, the drive-train is stock and the wheels were rotated with the noise not related to a specific wheel/tire combo.
Phil, correct me if I am wrong.But I think he's just saying to you, nonstop, that when those tires do finally start to wear, it will sound similar to the noise you heard when the bearing went. So you might think your bearing is messed up again when in fact it's the tires.
Mavrik
Re: 2003 Vibe needed New wheel bearing at 38,000 km (ragingfish)
Post by Mavrik »
yes thats what I ment Mike, that he should keep an ear to see if the sound does come back cause it likely will when those tires wear out. I am sure it was a bearing as he said since the noise is gone... but I had a Vibe here with that sound and it was the tires.basicly just giving you a heads up
nonstop
Post by nonstop »
No problem, I did catch the caution that pending tire wear could induce a similar sound. Appreciated very much.
pingber
Post by pingber »
Hey Mav --- are you a service person (ie. mechanic?) --- if so, have you been reading my posts re my vibe awd with either a transfer case problem or wheel bearing problem? Could use some advice.
pingber
Re: 2003 Vibe needed New wheel bearing at 38,000 km (pingber)
Post by pingber »
Hey --- got the car back from the dealer today & it was the bearing .... will wonders never cease
Mavrik
Post by Mavrik »
Quote, originally posted by pingber »Hey Mav --- are you a service person (ie. mechanic?) --- if so, have you been reading my posts re my vibe awd with either a transfer case problem or wheel bearing problem? Could use some advice.I used to work as a service advisor for GM/Pontiac/Buick until 2005 until jumping ship to Subaru in 2005 when I moved. To answer your question though I have heard of bearings on wheels and in transmissions going bad on the Vibes. Not on mine though fortunatly and I take mine to its limit all the time.
