Fog Light Removal
LesPaul
Fog Light Removal
Post by LesPaul »
...Im trying to take out my fog lights, I took a good look at it yesterday....there seems to be some sort of backing plate (with 2 or 3 screws) holding it in place, do i need to remove these, or does anyone know an easier way to to this...thanks guys
Mr. Poopypants
Re: Fog Light Removal (LesPaul)
Post by Mr. Poopypants »
I would say that those screws will probably get the light out. Try it out and let us know.
AKLGT
Post by AKLGT »
did you do a search? i know there are some pics of the manual showing how to remove them. that's what i did when i replaced mine. but it was so long ago i don't remember. sorry.
AKLGT1998 Subaru 2.5RS
LesPaul
Re: Fog Light Removal (trdvibe)
Post by LesPaul »
...no apology needed..I keep forgetting about the search function..anyway i found the link.http://forums.genvibe.com/zerothread?id=8343Im going to try this today.
THose instructions are for bulb removal, not the entire assembly...Which are you trying to get out?
LesPaul
Re: (ragingfish)
Post by LesPaul »
...That would be nice to know also does anyone know how to remove the whole fog light assembly
scherry2
Re: (LesPaul)
Post by scherry2 »
stick a small screw driver along the side of the lamp and lift the tab and the whole lamp will come out.
rodzombie
Re: (scherry2)
Post by rodzombie »
Quote, originally posted by scherry2 »stick a small screw driver along the side of the lamp and lift the tab and the whole lamp will come out.You'll need to back out the adjuster screw also or just pop out the hole adjuster unit. (easier to just unscrew it though.)
scherry2
Re: (rodzombie)
Post by scherry2 »
Oh yea I remember.
LesPaul
Re: (rodzombie)
Post by LesPaul »
..thanks guys ,..Im no mechanic so bare with me, Im assuming that the adjusting screw is the screw thats located on the back of the housing..
satur9
Re: (LesPaul)
Post by satur9 »
any update
nicfortin
Post by nicfortin »
Anyone with a pic of that screw?Would be very very helpfull..Thanksnicolas
Jahntassa
Post by Jahntassa »
Getting the front fogs out is more a bear than the reverse lights. I would highly suggest taking the front fascia off the car to get access to the fogs. It'll take less time, and possibly prevent breakage.Here's a handy how-to! I did this the other day. Took me about 20 minutes for the first time I did it..http://forums.genvibe.com/zerothread?id=12551
