...Im trying to take out my fog lights, I took a good look at it yesterday....there seems to be some sort of backing plate (with 2 or 3 screws) holding it in place, do i need to remove these, or does anyone know an easier way to to this...thanks guys
did you do a search? i know there are some pics of the manual showing how to remove them. that's what i did when i replaced mine. but it was so long ago i don't remember. sorry.
Quote, originally posted by scherry2 »stick a small screw driver along the side of the lamp and lift the tab and the whole lamp will come out.You'll need to back out the adjuster screw also or just pop out the hole adjuster unit. (easier to just unscrew it though.)
Getting the front fogs out is more a bear than the reverse lights. I would highly suggest taking the front fascia off the car to get access to the fogs. It'll take less time, and possibly prevent breakage.Here's a handy how-to! I did this the other day. Took me about 20 minutes for the first time I did it..http://forums.genvibe.com/zerothread?id=12551
