Can we increase the font size in the forums...
Let us know of any problems, suggestions, or questions you have about the GenVibe Website and Forums
SBC31
Post by SBC31 »
They are way too freakin' small...Plus the ability to delete a thread you started by accident would be nice.
SBC31.COM
rasermon
Re: Can we increase the font size in the forums... (SBC31)
Post by rasermon »
I deleted your thread for you. For font size if your using IE, click on view/ text size and increase it to a larger size.
millster
Post by millster »
Also, if you have a mouse with a scroll wheel, hold CTRL and scroll up to decrease the font size and down to increase it.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
pmh013
Re: Can we increase the font size in the forums... (rasermon)
Post by pmh013 »
Quote, originally posted by rasermon »I deleted your thread for you. For font size if your using IE, click on view/ text size and increase it to a larger size. For me, that doesn't work. It only seems to change "The Online Community for Pontiac Vibe Enthusiasts" line.
NSimkins
Global Moderator
Post by NSimkins »
Someone else suggested that before along with different themes to use within your Personal Profile. I will work on getting a new profile together that will include larger font sizes for the forum. Stay tuned.Related: http://forums.genvibe.com/zerothread?id=10859
rasermon
Re: Can we increase the font size in the forums... (pmh013)
Post by rasermon »
Quote, originally posted by pmh013 »For me, that doesn't work. It only seems to change "The Online Community for Pontiac Vibe Enthusiasts" line.Your right! Very strange works with other forums I belong to.
The style that genvibe pages are rendered with defines the font size. If you "view source" for a thread, you can see the entryBODY, TD, INPUT, TEXTAREA, SELECT { font-family: Verdana, Geneva, Arial, Helvetica, Sans-Serif; font-size: 10px; }My guess is that this forces the text to be size 10, overriding local browser setting.Easiest solution is -> Use Netscape instead of IE, it will let you override the font size definition of the page here is a quick screen grab of the same page with both netscape and IE set to display text size as the largest possible. http://forums.genvibe.com/zerofile/4108/ns-ie.jpg
SBC31
Post by SBC31 »
I use Mozilla for browsing, and changed the minimum foint size to 16, thus making it better then the default one for this site.
SBC31.COM
You can also override the font size in internet explorer!Go to TOOLSINTERNET OPTIONSACCESSIBILITYPut a check mark next to IGNORE FONT SIZES SPECIFIED ON WEB PAGESClick OKClick OK againNow you can adjust the font size of ANY web page. Including genvibe!
NSimkins
Global Moderator
Post by NSimkins »
Quote, originally posted by SBC31 »They are way too freakin' small...As requested, I've made another forum style scheme that provides a bump up in font size (to 12-point instead of 10-point in the default scheme).To access the scheme selector, go to:1. My Profile - located at the top of each forum page2. User Options3. The fourth item down, Style Scheme, will let you select the default (GenVibe) or larger font size (GenVibe-Larger Font Size) schemes.If you find any problems with the new scheme, please let me know.Also note, if you decide to use the new larger font size scheme, be aware that the Instant Messaging window will remain at default font sizes in order to maintain aesthetic appearances.Enjoy!
Vibe
Re: Can we increase the font size in the forums... (NSimkins)
Post by Vibe »
Good Job & Thanks --I do agree they are too small. James (Vibe)
I am using the new style. Thanks Nick
Weird. Just for kicks I tried switching to the different scheme to see how it looked, and I would click save, and as soon as I navigate away from the options page, it would revert back to normal.
NSimkins
Global Moderator
Re: (ragingfish)
Post by NSimkins »
Quote, originally posted by ragingfish »Weird. Just for kicks I tried switching to the different scheme to see how it looked, and I would click save, and as soon as I navigate away from the options page, it would revert back to normal. I was talking to millster last night about this issue. Appears to be if you're using a browser other than IE, make sure you don't have any other sessions (Tabs) open. It seems the other windows may conflict with the style settings that GVC uses. Try that, if not, millster may be able to clarify more.
AKLGT
Re: Can we increase the font size in the forums... (joatmon)
Post by AKLGT »
Quote, originally posted by joatmon »I am using the new style. Thanks Nick thanks! i like this. being near sighted, this definitely helps!
AKLGT1998 Subaru 2.5RS
Vibe
Re:
Post by Vibe »
WOW!!! This is great --No more eyestrain---- James
Sputnik
Re: Re: (Vibe)
Post by Sputnik »
Yeah I like the new font size!
GenVibe Global Moderator
ToolGuy
Re: Re: (Sputnik)
Post by ToolGuy »
All the fonts on the site are too small...
AKLGT
Re: Re: (MiVibe-ToolGuy)
Post by AKLGT »
did you change it to the new font style?
ToolGuy
Re: Re: (trdvibe)
Post by ToolGuy »
Quote, originally posted by trdvibe »did you change it to the new font style?OK just did that and it is better, thanks.
