Seatbelt Lights
Aquasax
Seatbelt Lights
Post by Aquasax »
Does anyone know how to disable the passenger side Seat Belt flashing light that comes on. It's annoying if there is weight on the seat that isn't actually a person. I don't want to accidentally disconnect the AirBag too. Any suggestions? Thanks...I like
dlmetzger
Re: Seatbelt Lights (Aquasax)
Post by dlmetzger »
You might just want to buckle the seatbelt instead of disconnecting things, IMHO.Dan
Dan2003 Vibe GT (sold back to GM, lemon law)Abyss (Mono)17" Wheels
d_m_kolb
Re: Seatbelt Lights (dlmetzger)
Post by d_m_kolb »
I was just thinking the samething as dlmetzger. I wouldn't disconnect anything. You could do more harm than good. Just leave the seat belt clicked on the passanger side. When someone rides with you hopefully they will have enough sense to undo it and use it.
Aquasax
Re: Seatbelt Lights (d_m_kolb)
Post by Aquasax »
I guess that's an easy solution. It's just a pain in the (removed) to do that all the time - click it and unclick it. I'm lazy. I just figured someone else may have played around with it already and found a solution.
MA-VIBE-FAN
Post by MA-VIBE-FAN »
My thought would be to take a piece of black electrical tape, trim to cover light, and put in over it.
d_m_kolb
Post by d_m_kolb »
No one ever said you had to un click it everytime. The only time it would be unclicked is if someone was going to ride with you. When you get to where you are going and remove the weight leave it together. So allway leave it clicked even when you get out of the car.
Frosty
Post by Frosty »
A Ralph Nader safety type would advise that anything heavy enough that will cause the car to sense a weight heavy enough to require a seatbelt, should be stored in the trunk.That would solve the problem. Sorry for being such an old fuddy duddy. cheers! Ken.
Frosty 5 speed Vibe Power & Safety Packages. Naturally Aspirated my gallery
wrench79
Re: Seatbelt Lights (kshields)
Post by wrench79 »
i also hate that damn light. i was looking under the passenger seat and noticed two or three plugs. I'm gonna unplug one and see what happens. I'll let you guys know what comes of it.
2003 Lava Vibe GT.17''wheel package, 6spd, no sunroof.......oh well
lopers
Re: Seatbelt Lights (wrench79)
Post by lopers »
Why don't you just fold the front passenger seat forward and put your gear on the plastic cargo tray?
2003 Satellite Vibe
VibeInTx
Post by VibeInTx »
Hey- It's aquasax! I know you
lopers
Re: Seatbelt Lights (VibeInTx)
Post by lopers »
Another solution for this problem is to buy an extra metal clip and just stick it in the holster unattached from the strap.
2003 Satellite Vibe
Aquasax
Re: Seatbelt Lights
Post by Aquasax »
For the Record - I have no intention of messing with the 'safety devices' - it's a great feature in the driver's seat. Have you seen how sensitive the sensor can be in the passenger side? if you put a magazine on the sensor, it can start blinking - and MAN it get's annoying. When people ride with me - I make them wear their seatbelt (that is unless it's that time where we fit 10 people in the vibe and it just wasn't possible... ) The reason I haven't gone and disconnected anything is because I don't want to disconnect the airbag in the process. It's not a big deal...just a problem i figure other people have had, and I was hoping someone had found a safe solution... (man I sound like a little (removed)...sorry bout that)In other news - has anyone tried the "wet-wax as you dry" stuff? I used zip-it wash last week which has wax in it and it works ok. But man do a lot of bugs lose thier life below the grill!
NovaResource
Post by NovaResource »
A more simple solution would be to simply remove the light bulb behind the panel.
d_m_kolb
Post by d_m_kolb »
Just all ways keep the passanger side seat belt fasten. Then weight or no weight it wont go off.
Greg100575
Post by Greg100575 »
sorry for the late reply to this threadi was in the middle of replacing my factory radio, and noticed the passenger seatbelt light plug. its simply a 2 wire plug, i left mine unplugged and all is wellits been unplugged for about 2 weeks now with no troubles Greg
03 Aybss Vibe GT17' Wheels5% Tint
tahoan
Re: Seatbelt Lights (Frosty)
Post by tahoan »
If you drove a vibe, you would know there is no trunk. A jug of milk or a laptop should not set off the sensor according to the owners manual. That is probably the source of the complaint.
Re: Seatbelt Lights (tahoan)
Wow, what a blast from the past. I don't even think any of the above members are still with us. lol!What year is yours, btw? I think I recall reading something in my '03s manual that mentioned the light will be triggered by items sitting in the seat. At any rate, the '03s light is quite sensitive, it takes little to set it off.
