Just got a brand new 04 Vibe this Sat Day - problems
GoLowDrew
Post by GoLowDrew »
The sunshade does not slide back by itself. It does open with the power switch. Now there is a big scratch on the right side of the sun shade. If I push up the right corner, it will slide ok.Does other Vibes have the similar problem?Does it take a lot to fix it? Like taking apart the car?Thanks
2004 Vibe, Auto Trans. Built Sept 2003. Date in service May 2004. Sold May 2006.
Re: Just got a brand new 04 Vibe this Sat Day - problems (GoLowDrew)
Welcome to Genvibe, sorry to hear about a problem on such a new vehicle.Check out http://forums.genvibe.com/zerothread?id=4106 and http://forums.genvibe.com/zerothread?id=3600, maybe they are related, or are similar enough to be of some help.You should also be able to take it back to the dealer and make them fix it under warranty.
GoLowDrew
Re: Just got a brand new 04 Vibe this Sat Day - problems (joatmon)
Post by GoLowDrew »
Yes. I do have an appointment to take it in (and other prep items) on Thursday. Just to confirm. The sunshade CAN slide open when the sunroof is closed, right?In other words, let the light in. Someone please confirm.Thanks
Mike-NC
Post by Mike-NC »
Sorry to hear about your problems. Welcome!I guess I was just lucky, I developed the habit of opening the shade and/or leaving it open before I opened the sunroof.And, yes you should be able to open the shade independently of the sunroof.
2004 Salsa Two-Tone AWD M&T, Power Pkg., Factory 16" Alloys, cargo nets, cargo matMods: Kenwood wOOx mini-sub, front and rear mud flaps, 2 car seatsWeatherTech bug shieldWish List: Replacement Door speakers, Tint
you can open/close the sunshade when the glass is closed or when the glass is tilted up. The only thing you shouldn't be able to do is close the sunshade when the glass is slid back.
Stang2Vibe
Post by Stang2Vibe »
Is this a new feature for the 04 Vibes only? I didn't know that the shade was supposed to close by itself when the glass is slid back to the closed position.
kgenthe
Post by kgenthe »
I'm fairly certain the shade does NOT close by itself.If it closed with the sunroof... then it wouldn't be able to open independently of the sunroof. Meaning, you could only gaze at the moon with the sunroof open... which wouldn't make any sense.I have a moonroof in my Sunfire, I usually keep the shade thing open, unless its raining, then its depressing for me to see the rain beating on the top of the car. Maybe I'm just weird.
04 VibeManualFusion Orange Metalic97 Sunfire GTManualPurple MetalicYeah, the Sunfire is faster
Celtic_Curse
Post by Celtic_Curse »
New car has problem just take it in and ask the people who sold it to you to fix it. If there is nothing to fix then your good if there is then you get it fixed, very simple.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
GoLowDrew
Re: Just got a brand new 04 Vibe this Sat Day - problems (Stang2Vibe)
Post by GoLowDrew »
Quote, originally posted by Stang2Vibe »Is this a new feature for the 04 Vibes only? I didn't know that the shade was supposed to close by itself when the glass is slid back to the closed position.I'll confirm that, it's how my is working now. Dealer has the car now. They say it will take TWO days. The tech called and thought I was taking about the sun visor.
Quote, originally posted by Stang2Vibe »Is this a new feature for the 04 Vibes only? I didn't know that the shade was supposed to close by itself when the glass is slid back to the closed position.My '03 does.... When the moonroof is closed, shade pushed back, and I make a quick stop it will close anywhere from 1/2 to 3/4 of the way. It's not a really "feature," it's just broken. It has been doing this for a year now, but I haven't bothered to get it fixed. I would get it fixed, but it took forever to get the greasy fingerprints off the headliner from the last time they worked on the moonroof.
NSimkins
Global Moderator
Post by NSimkins »
Quote, originally posted by GoLowDrew »Dealer has the car now. Let us know the end result.Quote, originally posted by ColonelPanic »My '03 does....I know I've heard that the moonroof shade in many '03s were exhibiting some intermittent problems like you describe as well as rattles from the cover itself (a problem I have). Apparently they had to redesign the shade a little to rid those little problems. Get it checked out before warranty is up.
Re: Just got a brand new 04 Vibe this Sat Day - problems (ColonelPanic)
Quote, originally posted by ColonelPanic »My '03 does.... When the moonroof is closed, shade pushed back, and I make a quick stop it will close anywhere from 1/2 to 3/4 of the way. It's not a really "feature," it's just broken. It has been doing this for a year now, but I haven't bothered to get it fixed. I would get it fixed, but it took forever to get the greasy fingerprints off the headliner from the last time they worked on the moonroof. Same with me...mine slides closed, quite irritating...I just stuck some paper in between the shade and the headliner, keeps it from closing on me.
GoLowDrew
Re: Just got a brand new 04 Vibe this Sat Day - problems (NSimkins)
Post by GoLowDrew »
Quote, originally posted by NSimkins »Let us know the end result.I know I've heard that the moonroof shade in many '03s were exhibiting some intermittent problems like you describe as well as rattles from the cover itself (a problem I have). Apparently they had to redesign the shade a little to rid those little problems. Get it checked out before warranty is up.Got the car back. All they did was order a new sun shade which will take two days. Did not find any problems, other than the evidence of the damaged sun shade. I hope it won't scratch up the new shade when the installed it.
The sunshade closing on its own finally got to me, so I scheduled an appointment with the dealer on Monday. I wonder if they'll replace the shade or just find some way to fix it...
Reynoma
Post by Reynoma »
My shade does come back slightly (maybe 1/8 to 1/4 of the way closed), nothing that I get excited about. I does not; however, close by itself when I close the moonroof.
Philippians 2:11
jake75
Post by jake75 »
I am glad I held out for a car without a moonroof. They were in the minority. Perhasp that's why the one I finally found had been around awhile.
GoLowDrew
Post by GoLowDrew »
Dealer fixed it yesterday. When they took it apart, they found a bolt that must have fell in when they built the car. That was the cause that scratched up the sunshade/prevent it from opening.
Reynoma
Post by Reynoma »
Glad to hear it was an "easy" fix...nothing major.
Philippians 2:11
Got my moonroof shade fixed today, somehow they were able to increase the tension for the shade. Now it's very difficult to slide back. That has definitely fixed it.Just as expected, I had to clean the headliner and shade, they got grease all over the place. I picked up a can of that Blue Magic spot remover stuff at AutoZone, worked like a charm.
