Performance Header?
Shadow-Vibe
Performance Header?
Post by Shadow-Vibe »
Does anyone know of a performance header made for the Vibe or Matrix? If not how many people would be interested in one? I have a local guy that may be willing to make some if he gets a lot of offers for them!!!
ebslopp
Re: Performance Header? (Shadow-Vibe)
Post by ebslopp »
I've seen them before, not sure where though. There was a discussion a while back about a performance header for our engine. Someone actually put one on their car and had a dyno test done. The results were minimal. Perhaps if you put a performance header and a unichip you'd see better results.
wicked1981
Re: Performance Header? (joatmon)
Post by wicked1981 »
Quote, originally posted by joatmon »would this work?http://cgi.ebay.com/ebaymotors...&rd=18 to 15 hp increase? Not bad for $189 wonder if it works like it says though.
drunkenmaxx
Re: Performance Header? (wicked1981)
Post by drunkenmaxx »
Quote, originally posted by wicked1981 »8 to 15 hp increase? Not bad for $189 wonder if it works like it says though.>"Show me the dyno!"
Thewhite
Post by Thewhite »
Quote, originally posted by joatmon »would this work?don't see why not...8-15 hp: large range, meens he probably don't know what's the real increase.http://www.jpperformancellc.com/matrixc.html350$, it's expensive for a 6-9 hp. between both? I'll go the one on eBay
'03 Vibe StandardFast Wheel Talon 17x7 Toyo Proxes T1-S 225/45Magnaflow Cat backDevelop's Strut Tower Brace
savedbyzero
Re: Performance Header? (Thewhite)
Post by savedbyzero »
Need Dyno. I believe there's also one put out for the 1ZZ by Hot Shot, there's the Trial header from Japan for the 2ZZ (pricey!) And DC Sport has one in the making for both 1ZZ/2ZZ that's being proto on a few Celica's I believe. Slowly but surely, we'll have more choices! I had a Pacesetter on my Sunfire. Biggest improvement out of all my mods!
THIS IS WHAT I DO...http://www.studiothisis.com
drummerdude
Re: Performance Header? (savedbyzero)
Post by drummerdude »
i'm going to have to go with... ITS ALL ABOUT THE 2ZZ!! no all but in my world it is seeing as how i don't have a 1zz.... just me!
2006 MazdaSpeed6 GT which is for sale if anyone is interested...
drunkenmaxx
Re: Performance Header? (drummerdude)
Quote, originally posted by drummerdude »i'm going to have to go with... ITS ALL ABOUT THE 2ZZ!! no all but in my world it is seeing as how i don't have a 1zz.... just me! that whole post confused mefrom what i have read on GV, the headers have not been a very effective mod for the vibe. apparenty, gains were minimal and in some cases, there were actually losses
savedbyzero
Re: Performance Header? (drunkenvibe)
I'm confused as well...Anyways, the AMSS header is one to stay away from. No gains and possible loss.
Psychobroker
Post by Psychobroker »
Apparently, the stock GT header is as highly tuned as possible (or close to it). It might be different for the 1zz motor, and based on JP's product description, I assume their header is for the 1zz only:Quote »Our headers use the highest quality T-304 stainless steel, CNC flanges, mandrel bent tubing and two stage ceramic coating. Precision welding techniques ensure excellent durability and accurate fitting to factory locations. Designed for use with TRD Supercharger in mind, but will work with normally aspirated motors as well. 5hp-9hp (Normally Aspirated Applications)My translation: This header is for the 1zz engine with gains being more substantial when used with a TRD supercharger, which is only abailable for the 1zz
Devlop
Re: Performance Header? (Psychobroker)
Post by Devlop »
Yes the header is for the 1zz only. The exhaust mainfold on the 2zz is highly designed and does not need to be replaced. The 1zz on the other hand, sucks balls and is poorly designed. This mod will help alot.
blk182@n7
Re: Performance Header? (Devlop)
Post by blk182@n7 »
Quote, originally posted by Devlop »Yes the header is for the 1zz only. The exhaust mainfold on the 2zz is highly designed and does not need to be replaced. The 1zz on the other hand, sucks balls and is poorly designed. This mod will help alot.LOL...just funny to funny
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
DavidPIL
Post by DavidPIL »
Hey all...You all know a lot more about this than I ever could but I think those headers show a 4 into 1 where the main exhaust is a 3" pipe instead of our 2.25". Wouldn't that in itself need a completely different exhaust with at least a 3" diameter tubing? I would guess that gains could be made with this increase in diameter alone, correct? So maybe it's not the headers that makes this an improvement but the 3" tubing and the need for the exhast upgrade?Just wonderin...Dave
Harry
Re: Performance Header? (DavidPIL)
Post by Harry »
Does anyone know where I can get a stock header and throttle body for a base 2004 Vibe? I am planning to build a header and play around with a larger throttle body, along with a few other tricks before I move up to a turbo. I’d like to get the stock pieces so that I could develop these parts and build them without having the car off the road. I’d also be interested in finding a Vibe GT intake assembly to play around with. Please let me know if anyone has these pieces or knows where I could get them. Thanks.Harryhwojo@juno.com
rodzombie
Re: Performance Header? (Harry)
Post by rodzombie »
Harry, Try looking here for a used throttle body and exhaust manifold. http://www.car-part.com/index.htm Lots of salvage yards all over the U.S. and Canada.
