engine shudder
pojamas
engine shudder
Post by pojamas »
I notice that when my 03 vibe gt is idling the car vibrates on the inside much like an old car with alot of miles. I feel the vibrations through the pedals, my seat, and the steering wheel. Did this happen to anyone else and do you know what it can be?
Re: engine shudder (pojamas)
a rough idle could be time for a tune up. how many miles do you have on it? welcome to genvibe!
pojamas
Post by pojamas »
20000
does the engine seem to be runnning rough at idle? if not and normal engine vibration isn't being damped properly, maybe there an engine mount problem. Was it always this way, or did it recently develop? maybe you can hit up a dealer to see how much a new vibe shakes at idle, and if your's is noticeable worse, get the dealer to fix it for free since it's still under warranty w/ only 20K miles.
robdog
Post by robdog »
maybe someone put a bannana in your tailpipe!!!
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
tune up??? tune ups are not due for over 100,000 miles on this engine. I'd say the banana is a better bet....he, he, he
Stang2Vibe
Post by Stang2Vibe »
I notice my GT shakes a bit at a certain RPM when idling before it is warmed up and drops to the lowest idle. It doesn't seem as bad in my car as you describe in yours, though.
goodvibe
Re: engine shudder (Stang2Vibe)
Post by goodvibe »
Same here when the idle drops and the car isn't fully warmed up. Never bothered me either. Use the gas to push the idle up 100 rpm. It will probably stop shaking. If it works, maybe your can adjust it. If it's gone when warmed up, it's normal.
pojamas
Post by pojamas »
No my engine could be completely warmed up. The last time it did it, the dash board was actually vibrating.
Re: (maxx4me)
Quote, originally posted by maxx4me »tune up??? tune ups are not due for over 100,000 miles on this engine. I'd say the banana is a better bet....he, he, heUnder normal circumstances, absolutely.But I've had two friends who bought new cars that weren't properly tuned at the factory (or received bad parts or something of similar nature) who had to have tune-ups well before 100,000 miles (under warranty, of course).Ahhh...the expensive-to-maintain technology that is the modern automobile.
roddney1
Post by roddney1 »
Check to see if all your plug wires are on good.
PONYAK TWO2004 Fusion Orange VibeMoon & Tunes, Autotrans, Power Package, Protection Package, Polished Steel Exhaust, Aluminum Wheels, Bumper Protector. ABS.Mods... Hella Horns, installed rear cargo carpeting.
Re: (pojamas)
Quote, originally posted by pojamas »No my engine could be completely warmed up. The last time it did it, the dash board was actually vibrating.that does sound wrong. there could be a bunch of things causing a rough idle. What does the tach show as your idle RPMs?Sounds like a visit to the dealer for warranty service. cost of a vehicle is what pays for the warranty, might as well use it.
pojamas
Post by pojamas »
The car idles at a normal 800-900 rpms
Re: (pojamas)
there are some other threads here about rough idle, some members, such as coratz and millster mentioned having similar probs, but never said if they got the prob fixed or what the cause was. If you do get it figured out, plost the results
Stang2Vibe
Re: (roddney1)
Quote, originally posted by roddney1 »Check to see if all your plug wires are on good.The Vibe's ignition is a coil-on-plug design. It has no spark plug wires.May be a motor mount causing the vibration. A mechanic should be able to do a visual inspection to see if this is the case. Do have it checked out.
goodvibe
Re: (Stang2Vibe)
Post by goodvibe »
Any motor mods? Oiled filter could foul the MAF.
roddney1
Re: (Stang2Vibe)
Post by roddney1 »
oops
Stang2Vibe
Re: (roddney1)
Don't worry roddney, it happens to the best of us!
pojamas
Post by pojamas »
I brought the car in for a warranty service and naturally they couldn't find anything wrong with it.
