polyurethane motor mounts.
GT_03
Post by GT_03 »
Does anyone know if these exist for the Vibes??? I have several buddies in the compact car world, and all of them have these???
Not a Vibe owner anymore
GT_03
Re: polyurethane motor mounts. (GT_03)
Post by GT_03 »
Stang2Vibe
Post by Stang2Vibe »
It looks like they will. If you have more questions about them, you might want to call PTuning. You've got me looking at them now too.
GT_03
Re: polyurethane motor mounts. (Stang2Vibe)
Post by GT_03 »
They are a must if you have a manual. Plus, you can't beat the cost. Pretty east to install also.
MJN2
Post by MJN2 »
I put Energy Suspension motor moutns on my last car ('99 Cougar), and they made quite a difference. Torque steer and wheel hop were noticably lessened.Can't beat the price, that's for sure.
Two-tone Neptune GT w/17" OEM rims, Nav System, BOMZ short ram, Sabresport STB
Jahntassa
Post by Jahntassa »
How painful is it to put that kinda thing in? Like..what'd be required to do it?
GT_03
Re: (Jahntassa)
Post by GT_03 »
Not to sure, but i got a email from Ptuning.com. They will be avaiable in 2 weeks, and they will fit the Vibe. I'm getting a set
cool vibes
Re: (GT_03)
Post by cool vibes »
? if you put these poly mounts in woudln"t feel the engine vibrations more? i would like to install these mounts to but?
satur9
Re: (cool vibes)
Post by satur9 »
thats one of the drawbacks...it shouldnt be that bad, much better than having wheelhop
MadBill
Re: (satur9)
Post by MadBill »
We better forward this link to GM so they can add these to the "Automatic Only" SC kit to quell the wheel hop that is supposedly holding up the release of the manual trans package...
GT_03
Re: (MadBill)
Post by GT_03 »
Madbill>>> How hard are these to install??? I figured you would probably know.
MadBill
Re: (GT_03)
Post by MadBill »
I haven't looked at the Vibe's mounts, but usually they aren't too hard to change. Generally you can loosen all the bolts on one mount at a time (to keep things in alignment), put a board under the oil pan, biased towards the mount you're trying to remove and jack the engine up enough to slide the old one out and the new one in, run the bolts in finger tight, repeat with other mounts, kinda shake the engine around a bit to make sure it's "settled" on the mounts and then torque all the bolts to spec.
satur9
Re: (MadBill)
Post by satur9 »
gm already knows. it was thier supposed fix for the problem.i dont know what the hold up is now.... mabey they killed to many clutches???
JohnC
Post by JohnC »
I ran poly mounts in my Dodge Neon mostly due to a very poor front mount design (easily failed and oem part was $70) it vibrated the whole car. Took alot to get used to it, then finally an aftermarket mount was available so I went back to the smooooooooooth rubber. They are a must have if you do frequent launches.
dmitri
Re: (JohnC)
Post by dmitri »
based on the price they look like a very good deal since i do frequent launches and i do get wheelhop at times. do they come with instructions or a diagram where the stock mounts are?
dmitri
Re: (dmitri)
Post by dmitri »
anyone know?
Psychobroker
Re: (dmitri)
Post by Psychobroker »
I dunno, but I'm ordering them right now anyway :-)
GT_03
Re: (Psychobroker)
Post by GT_03 »
I just palced my order also
drummerdude
Re: (Psychobroker)
Post by drummerdude »
Quote, originally posted by Psychobroker »I dunno, but I'm ordering them right now anyway :-)let us know how they turn out and see if you can do step by step instructions with pics... that would be cool!
2006 MazdaSpeed6 GT which is for sale if anyone is interested...
GT_03
Re: (drummerdude)
Post by GT_03 »
Well, i got them in already!!! 36 hours after placed order!!!! I love ptuning.com I have to wait for some warmer weather to attempt this, but it doesn't appear too hard, only prob is the directions are just general, not for any certain make or model. Here's a pic
