Stock Shift Knob - loose?
TriGuy
Post by TriGuy »
I've noticed that my shift knob was somewhat loose when I got from the dealer. I had to tighten it about one full turn...Anyone else notice this?
Re: Stock Shift Knob - loose? (TriGuy)
Haven't heard of anyone else having that problem -- though because it's SO easy to fix, people may not bother to mention it if it happened to them...In any case, could just have been a fluke, I wouldn't worry about it unless it comes loose again...Though I would've expected the dealer to notice it when they took it in for detailing and I'd think they would have fixed it for you...but who knows...
Mavrik
Re: Stock Shift Knob - loose? (ragingfish)
Post by Mavrik »
My base Vibe 5spd shifter was loose as well. I turned it by hand about 2 full turns to get it on there tight enough that it doesn't move when I shift. I kinda was glad it was loose so I could put it in just the right spot for me to feel comfortable with it.
I think mine might have been a bit loose when I got it. I sometimes spin it off and back on while driving, something to do on a long commute.
BubbaBlueyz
Re: Stock Shift Knob - loose? (joatmon)
Post by BubbaBlueyz »
mine was loose when i got my 6 speed vibe!
DavidPIL
Post by DavidPIL »
Hi TriGuy...Mine was fine when I got mine but it had to be driven from another lot about 90 miles away so I'm sure whomever drove it would have tightened it.I took it in for a regular oil change and had em check the clutch and look into the notchiness. When I got it in, the shifter wasn't even lined up right. about a turn and a half to tighten it. Maybe the ones with the loose shifters, the mechanics at the dealership, maybe in a pre-delivery check, look into something under the shift boot... I know I took mine off, used a little lithium grease and Presto!, smoother shifting!Just a thought...Dave
AKLGT
Re: Stock Shift Knob - loose? (DavidPIL)
Post by AKLGT »
nope. mine was fine, but then i took it off about 2 days later to paint the interior parts.... so it could've been i guess.
AKLGT1998 Subaru 2.5RS
