Today with the help of my girlfriend, I was able to finally install my under-dash red cold-cathode lights!I used a single kit and a bulb from frozecpu.com. I used their red 4" kit, and connected both bulbs to it. What I did was tap into the power supply from the cig lighter, and put the control box in the center under the shifter. I then had both lights go out from the center posisition; however, I did have to solder in wire extensions to the lights. Did some other funky mounting things - and installed them so you cannot see the bulbs unless you stick your head under there. I might go for something a little brighter, but this works fine for now! Actually, the red in the picture is darker than the ACTUAL red it shows, the red that it really is matches more of the background red to the stock radio display. Total time to do everything was ~ 2 hours, give or take a half hour. I have a switch to turn them on and off, and right now that is just hanging inside the front console garbage can, and I will mount that later on, possibly with a small hole in the side of the plastic I now realize that I /need/ rear lights as well for the rear seats, but at least these will be easier to install as well. (Much thanks goes to RaginFish for his How-tos on removing the shifter assembly, and the center console assembly - they came in extremely helpful!)Comments welcome!
That's awesome man.Take into consideration the green of the cig lighter and the green on the shifter, you're all set for xmas! hehe...Seriously though, are the bulbs interchangeable? Could you get different colors if your interests changed?
How'd you mount the bulbs, exactly? I need to put in the neon from my Probe into the Vibe, and as of yet, I haven't quite figured out how... I have two 6" neon bulbs to go under the dash, and two 10" to go under the seats...It is, of course, already pre-wired.. I ran the switches into the little pocket to the left of the steering wheel, along with my amp cut-off switch and remote level control for the subs.Yours looks sweet, btw! I love the cold-cathode idea!
Quote, originally posted by Jahntassa »How'd you mount the bulbs, exactly? I need to put in the neon from my Probe into the Vibe, and as of yet, I haven't quite figured out how... I have two 6" neon bulbs to go under the dash, and two 10" to go under the seats...Here's what I did: I had 2 peices of aluminum left over from a previous project. I used automotive tape to tape it under the passenger side, attached to the metal part as you can see:This gave me ample space to mount the light under, there is a little chance that someone can kick the light, but because it is attached with the velcro, it will just come off instead of breaking.For the driver side, I used the same idea, only instead I wedged the aluminum under the dash plastic and the metal part of the dash as you can see. I put tape there too to hold it in place. I then used a peice of foam on the edge of it, so I could mount the light totally hidden from view as you can see:I still need to put some wire-loom over the white cables to further hide them, but that's what I have done so far. If the tape doesn't hold, I will find another way to do it, but this makes things relativly easy to return to stock should I decide to remove the lights if I ever sell the car.If ya have anymore questions, let me know!
I am really not one to have neon lights in/on my car but I've got to say... that looks GREAT!Good job.
Car: 2003 Two tone Base Frosty Vibe, Automatic, Safety & Security Package, Power Package and 16" alloys with 16" Blizzaks for winterNavigation: HP iPAQ 2210 + LeadTek 9537 BT GPS + iGuidance V2.1.1 + German-D mount.http://www.howardforums.comYour Mobile Phone Community & Resource
I have an idea for your rear seat lighting...My driver's side foot well thing is iluminated by the switch for my underbody kit. and the rest of my car is lit up bright red by my dome lights. I bought a set of red sleaves at autozone for $1.50. Extremely cheap for such a great affect. Mine are starting to fade though after about 2 weeks but they are only $1.50 so I'm gonna go tomorrow and buy a bunch more.Now all you need is this...
Arcs, you /have/ to get pics of the blue lights!!! I bet that would look dynamite in there, brighter too!!!I considered getting blue bulbs, but wanted everything to match as there was no other blue in the dash. Perhaps if I got a blue lighted Head unit and blue interior dome lights that would pull things together ...Can't wait to see what ya do with em!
I'm gonna have to get some red to put in mine...I have blue (two 6" tubes and two 10" tubes), but as the car is red...blue wouldn't match well..I think i'm also going to put some LEDs in the front door handles.. Point them so they aim at the window controls...it's a little annoying that the only thing that lights up is the "auto" on the driver window...
Looks awesome! I just tried this, and I couldn't get it to work. I'm using the same kit and everything. The white wire with the black stripe is the 12V source and the grey is the ground. The yellow wire coming out of that blue converter box goes to the 12V and the black goes to the ground. All my connections are good, but the lights wont come on... What am I missing?
Your red LED's are pretty sweet, vibe_raider... I just added some blue LED's under my dash... I bought two of these things here:http://store.tireflysonline.co....htmlI like the small size of these, they could be mounted pretty much anywhere. Found perfect spots to mount them on the A/C housing or whatever it is under there. Tapped into power (switched with the ignition) using an add-a-circuit. Also popped out a blank, adding a switch to control them as well.I mounted them yesterday, but didn't have power ran for them yet. So I just took a 9V and hooked them up to it to see what they look like... Pretty nice, lights up a good portion of the floor, and even shines on the door panels a little. I'll try to get some pics of them tonight.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
