Under-dash lights installed!
Geo
Post by Geo »
Today with the help of my girlfriend, I was able to finally install my under-dash red cold-cathode lights!I used a single kit and a bulb from frozecpu.com. I used their red 4" kit, and connected both bulbs to it. What I did was tap into the power supply from the cig lighter, and put the control box in the center under the shifter. I then had both lights go out from the center posisition; however, I did have to solder in wire extensions to the lights. Did some other funky mounting things - and installed them so you cannot see the bulbs unless you stick your head under there. I might go for something a little brighter, but this works fine for now! Actually, the red in the picture is darker than the ACTUAL red it shows, the red that it really is matches more of the background red to the stock radio display. Total time to do everything was ~ 2 hours, give or take a half hour. I have a switch to turn them on and off, and right now that is just hanging inside the front console garbage can, and I will mount that later on, possibly with a small hole in the side of the plastic I now realize that I /need/ rear lights as well for the rear seats, but at least these will be easier to install as well. (Much thanks goes to RaginFish for his How-tos on removing the shifter assembly, and the center console assembly - they came in extremely helpful!)Comments welcome! :D
BADGER PRIDE
NSimkins
Global Moderator
Re: Under-dash lights installed! (Geo)
Post by NSimkins »
Very cool Geo! ... love that red!
ragingfish
Post by ragingfish »
That's awesome man.Take into consideration the green of the cig lighter and the green on the shifter, you're all set for xmas! hehe...Seriously though, are the bulbs interchangeable? Could you get different colors if your interests changed?
2009 PONTIAC G8
Geo
Re: Under-dash lights installed! (ragingfish)
Post by Geo »
Yep, as long as I get the same style of bulb connecter, can relativly easily change the bulb colors.I might even do blue for the future, we'll see
BADGER PRIDE
Jahntassa
Post by Jahntassa »
How'd you mount the bulbs, exactly? I need to put in the neon from my Probe into the Vibe, and as of yet, I haven't quite figured out how... I have two 6" neon bulbs to go under the dash, and two 10" to go under the seats...It is, of course, already pre-wired.. I ran the switches into the little pocket to the left of the steering wheel, along with my amp cut-off switch and remote level control for the subs.Yours looks sweet, btw! I love the cold-cathode idea!
Nervous_Dog
Post by Nervous_Dog »
Looks good
Nervous Dog2003 Monotone Lava GT w/ M&T and PowerMods: 18" Bronze Tenzo-R Mean Six rims w/ Kumho MX12" Rockford Fosgate Punch Sub in slot ported box2 - Rockford Fosgate Punch 201S amps2 pair - Rockford Fosgate P162C in front/rear doorsSony Xplod 5710 head unitHidden Hitch
Geo
Re: (Jahntassa)
Post by Geo »
Quote, originally posted by Jahntassa »How'd you mount the bulbs, exactly? I need to put in the neon from my Probe into the Vibe, and as of yet, I haven't quite figured out how... I have two 6" neon bulbs to go under the dash, and two 10" to go under the seats...Here's what I did: I had 2 peices of aluminum left over from a previous project. I used automotive tape to tape it under the passenger side, attached to the metal part as you can see:This gave me ample space to mount the light under, there is a little chance that someone can kick the light, but because it is attached with the velcro, it will just come off instead of breaking.For the driver side, I used the same idea, only instead I wedged the aluminum under the dash plastic and the metal part of the dash as you can see. I put tape there too to hold it in place. I then used a peice of foam on the edge of it, so I could mount the light totally hidden from view as you can see:I still need to put some wire-loom over the white cables to further hide them, but that's what I have done so far. If the tape doesn't hold, I will find another way to do it, but this makes things relativly easy to return to stock should I decide to remove the lights if I ever sell the car.If ya have anymore questions, let me know! :D
BADGER PRIDE
huy397
Re: (Geo)
Post by huy397 »
I am really not one to have neon lights in/on my car but I've got to say... that looks GREAT!Good job.
Car: 2003 Two tone Base Frosty Vibe, Automatic, Safety & Security Package, Power Package and 16" alloys with 16" Blizzaks for winterNavigation: HP iPAQ 2210 + LeadTek 9537 BT GPS + iGuidance V2.1.1 + German-D mount.http://www.howardforums.comYour Mobile Phone Community & Resource
AKLGT
Post by AKLGT »
that looks great geo! i'd love to do something similar.
AKLGT1998 Subaru 2.5RS
Merzbow
Post by Merzbow »
I have an idea for your rear seat lighting...My driver's side foot well thing is iluminated by the switch for my underbody kit. and the rest of my car is lit up bright red by my dome lights. I bought a set of red sleaves at autozone for $1.50. Extremely cheap for such a great affect. Mine are starting to fade though after about 2 weeks but they are only $1.50 so I'm gonna go tomorrow and buy a bunch more.Now all you need is this...
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
TheDude
Post by TheDude »
very nice job Geo, i absolutely hate it when people mount neons, yet allow the bulb to show. Great job hiding the neon up in the dash
Model: 2003 GT Color: 2 tone Abyss My Kills: late 90's tricked out cavalier Stereo: Pioneer DEH-8500mp, Rockford 6 1/2's all around(FRC4306) Comming soon Custom Fiberglass Box, Audiobahn 1206t, Rockford X6(for Sub), Kenwood KAC-8401(for Speakers) Audiobahn 3 Farad Cap
ArcsVibe
Post by ArcsVibe »
Love it bro very nice! I just ordered some blue ones and can't wait to install them...
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
Geo
Re: Under-dash lights installed! (ArcsVibe)
Post by Geo »
Arcs, you /have/ to get pics of the blue lights!!! I bet that would look dynamite in there, brighter too!!!I considered getting blue bulbs, but wanted everything to match as there was no other blue in the dash. Perhaps if I got a blue lighted Head unit and blue interior dome lights that would pull things together ...Can't wait to see what ya do with em!
BADGER PRIDE
ArcsVibe
Post by ArcsVibe »
I promise to post some pics when I get them!I just paid them off a guy from Ebay and should get them hopefully before Christmas, I cannot wait!!
VOTM April 06
HammerHead
Post by HammerHead »
Great Job Geo. Looks Great!
Hammer
Jahntassa
Post by Jahntassa »
I'm gonna have to get some red to put in mine...I have blue (two 6" tubes and two 10" tubes), but as the car is red...blue wouldn't match well..I think i'm also going to put some LEDs in the front door handles.. Point them so they aim at the window controls...it's a little annoying that the only thing that lights up is the "auto" on the driver window...
namhtam
Post by namhtam »
Looks awesome! I just tried this, and I couldn't get it to work. I'm using the same kit and everything. The white wire with the black stripe is the 12V source and the grey is the ground. The yellow wire coming out of that blue converter box goes to the 12V and the black goes to the ground. All my connections are good, but the lights wont come on... What am I missing?
Geo
Post by Geo »
Check the thread over at MatrixOwners, I posted a reply there :D
BADGER PRIDE
ArcsVibe
Re: (Geo)
Post by ArcsVibe »
I received my blue neons cracked from the shipping so I guess I will have to get another set and post the pics then.
VOTM April 06
Merzbow
Re: (ArcsVibe)
Post by Merzbow »
You got a set of under-dsah neons? or underbody neons??
FusionVGT
Re: (Merzbow)
Post by FusionVGT »
I have to admit this looks a lot better than I thought it would
RcRacer440
Re: (FusionVGT)
Post by RcRacer440 »
I have red L.E.D.s in the air vents and I'm putting in some red tubes under the dash today. Check out the pics at cardomain on the bottom of this.
2003 Lava 2-tone GT:Remote Start,Borla exhaust, K&N intake, orange undercar neons, 7 color undercar L.E.D.s, stobe lights, spoiler, moon & tunes, grafxwerks,satelite radio, PA system Pics of my Vibe http://www.cardomain.com/memberpage/373589
vibe_raider
Re: (RcRacer440)
Post by vibe_raider »
that is just too awesome! I plan on doing that next, i just got a red underbody led kit for my car. the front looks like night rider *heh*
My other ride is a ...
Re: (vibe_raider)
Your red LED's are pretty sweet, vibe_raider... I just added some blue LED's under my dash... I bought two of these things here:http://store.tireflysonline.co....htmlI like the small size of these, they could be mounted pretty much anywhere. Found perfect spots to mount them on the A/C housing or whatever it is under there. Tapped into power (switched with the ignition) using an add-a-circuit. Also popped out a blank, adding a switch to control them as well.I mounted them yesterday, but didn't have power ran for them yet. So I just took a 9V and hooked them up to it to see what they look like... Pretty nice, lights up a good portion of the floor, and even shines on the door panels a little. I'll try to get some pics of them tonight.
Image Image
Re: (ColonelPanic)
...And here are a couple pics of my new setup. I kinda like them...
Image Image
Re: (ColonelPanic)
And another...
Image Image
AKLGT
Re: (ColonelPanic)
Post by AKLGT »
very cool. looks much better than my $6 walmart rice LED runway rope!
vibe_raider
Re: (ColonelPanic)
aww, thanks colonel
