What is the skidpad difference with 16's and 17's
robdog
Post by robdog »
Does anyone know the difference in skidpad #'s when someone has stock 16's and someone else with stock 17's. .........just curious
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
goodvibe
Re: What is the skidpad difference with 16's and 17's (robdog)
Post by goodvibe »
When the mags tested these, the stock 17s did much better but it wouldn't be the rim diameter. It's more a function of the tire types and size with their respective wheel widths. Stickier and wider is what gets it done. A 225/50/16 should do as well or better than a 215/50/17 of the same type if both are on 7" wide rims. The base and GT should be similar in skid pad #s with the same tire but the GT will slolam better with its firmer shocks. No hard #s here but I hope it helps.
