Spare Tire Pressure Check
RoundUp
Post by RoundUp »
Just out of curiosity, does anyone check the pressure of their spare regularly? I check my tires at least once a month, but I only checked the spare today for the very first time. And it's a pain! Had to move everything out of the back, take the spare out and flip it over to do the check. I did this in my parking spot. Can't imagine doing this regularly at the gas station when I adjust the other tires.
meathead333
Re: Spare Tire Pressure Check (RoundUp)
Post by meathead333 »
thatd be the reason why i have never checked mine, i am too lazy to move everything out.
My myspace.com profile My 73' Bronco Cardomain page
I haven;t done it in my Vibe yet, but it is a good idea to do it periodically. Didn't check it on my last car, and I can testify that it really sucks to try to replace a flat tire with a flat spare.At least I still have a couple months of 1800ROADSID left.
MadBill
Re: Spare Tire Pressure Check (meathead333)
Post by MadBill »
Maybe you can just give it a squeeze or a bounce with a hammer every so often, to see if it's gone soft. Big rig drivers develop a good feel for how a rubber hammer (or even the toe of a boot) should bounce off their 18 plus tires...
I check it once in a while...but not often...
Lancer
Post by Lancer »
Mine is in the basement until the snow starts to fly.
NovaResource
Post by NovaResource »
Griot's Garage has is the answer to your problem:EASY ACCESS, SPARE TIRE AIR LINESpare tires that are remotely located should be checked periodically for correct tire pressure. Here's a way to conveniently check the pressure and fill the tire without even lifting the carpet! Connect our Spare Tire Airline to the spare tire's valve, and its long 42" length will extend into the trunk or luggage area. Use a tire gauge to check your correct pressure. If it's low, add air pressure as you normally would on the same end! No more useless, flat spares! Red hose for easy visibility. Indispensible for hard-to-reach spare tires. 44407 Spare Tire Air Line $9.95 http://www.griotsgarage.com/catalog.jsp ... &SKU=44407
Re: Spare Tire Pressure Check (NovaResource)
That's pretty cool.
RoundUp
Post by RoundUp »
Must say that I am impressed!
GMJAP
Post by GMJAP »
I was checking my tires today and figured I should check the spare too. Man, it is a pain in the (removed)! (Still in the 05!) You can't get to the spare air stem without taking the darn spare completely out.So I found this ancient thread. I'll have to check and see if that Air Line is still around.
zionzr2
Post by zionzr2 »
i think i may have to get a couple of those.then i would actually be more inclined to check...as it is now i do not I also hate dougnut spares....I miss having a full-sized spare!!
Baltovibe
Re: Spare Tire Pressure Check (GMJAP)
Post by Baltovibe »
Quote, originally posted by GMJAP »I'll have to check and see if that Air Line is still around.Didn't find it at Griotsgarage, but did find a similar one called Chek-A-Spare.http://www.getagauge.com/USAProducts.cfm
zionzr2
Post by zionzr2 »
yep found the same one and its only $6
Pick
Post by Pick »
I have no reason to check it's pressure, i carry an air pump in there, plus plugging tools to fix a flat so i don't even have to bother using the spare unless i totally destroy a tire.
Eric05 Vibe
GMJAP
Re: Spare Tire Pressure Check (Baltovibe)
Post by GMJAP »
Quote, originally posted by Baltovibe »Didn't find it at Griotsgarage, but did find a similar one called Chek-A-Spare.http://www.getagauge.com/USAProducts.cfm Thanks for posting that, Baltovibe! Great price too.I also carry an air compressor; maybe I'm just a little over-cautious once having had a flat and finding my spare flat too. If it's easy to check I think it's worth it once in a while to make sure the spare is okay (hasn't gone totally flat.)
zionzr2
Post by zionzr2 »
just ordered 2EDIT: 1 for the vibe and the other for my wife's car!!
northvibe
Post by northvibe »
now if we could only find a way to make them spin with out coming off and just have a pump in your trunk then u could have run flats!!
zionzr2
Post by zionzr2 »
WOW fast shipping!!Ordered Thursday about 5pm recived via mail Saturday!I routed it to the drivers side storage bin. very easy access..Showing the spares location and the path of the new hose.Storage Bin shot
Baltovibe
Re: Spare Tire Pressure Check (zionzr2)
Post by Baltovibe »
Quote, originally posted by zionzr2 »just ordered 2Thanks, Zionzr2! I was procrastinating on this item, but after seeing your success, I just ordered 2 also. Great routing job and pics! Thanks again!
GMJAP
Re: (zionzr2)
Post by GMJAP »
Nice job, zionzr2!I routed mine up to the hand-hole in the middle of the bumper side of the cargo floor. Probably not a very good description; maybe I'll get a pic too.
