Redacted
Vrypor
Redacted
Post by Vrypor »
Redacted
VibeNation2024
Re: Why does my 2005 Pontiac Vibe Base sound like an 18-wheeler?
Post by VibeNation2024 »
Thanks for the audio since it helps but I have a couple of other questions:
How many miles are on the vehicle?
Did changing the belt have any impact on the sound (better, worse, same)?
Did you have heat, A/C, fan, recirculate etc on when taking the audio?
Does the sound get better after driving and letting the engine warm up?
Does the car run normally or do you notice any issues with voltage reading, indicator lights, etc?
Vrypor
Redacted
Post by Vrypor »
Redacted
VibeNation2024
Thanks for the quick replies and the additional video clip. I was leaning toward a pulley or alternator bearing but when you rev the engine, you can see the dipstick vibrate and shake. That is interesting. I will have to do some research to steer you in the right direction. In the mean time, I'm hoping another member might have some expirience/input and will reply.
Vrypor
Redacted
Post by Vrypor »
Redacted
For something like that, I might try a quick test by removing the serpentine belt. If the sound goes away, then there's a good chance that its coming from something driven by the belt, which would be better than having it come from some engine internal. Of course, you only want to do that quickly, with the engine cold, since coolant won't circulate. And also, only reasonable if the sound is there when the engine is cold.
VibeNation2024
Vrypor- I haven't had a chance to investigate this more with work but wondering if the shop found anything or if joatmon's suggestion helped find the issue? If not, I should have time tonight to dig into further.
Vrypor
Redacted
Post by Vrypor »
Redacted
VibeNation2024
Haven't been able to get back until now. I was doing some more research and still agree with joatmon about checking the pullies. If one is bad enough, it could cause the vibration you see in the video (and feel when accelerating). Also, as a quick check, is your engine oil and trans fluid at the correct level? Or, did the shop get back to you and find anything?
Vrypor
Redacted
Post by Vrypor »
Redacted
guess its good that they found the issue, but I was hoping for something easier to fix, like a bad alternator or belt tensioner. Hope its back on the road soon.
