Unrelenting P0420 remains after catalytic converter, O2 sensors, and other parts replaced and modified
nato
Post by nato »
edit: Replaced catalytic converter, and a number of other parts before fixing it with spark plug non-foulers. The fix lasted two weeks which was more than enough time to pass smog. The thread subject was also modified more than once. See subsequent posts in this thread for more details.
Hi,
I have a 2005 Matrix XR with 271K miles that has a CEL that I need extinguished so I can get it to pass emission/inspection. I've checked it multiple times (and reset the computer) and it is usually just a P0420. Today I checked and also saw a P0171.
Details that may or may not be relevant:
  • About two years ago I was in the same situation of having a P0420 and needing it extinguished. I was thinking at the time I wouldn't have the car more than 6 more months so I replaced the catalytic converter with a $120 version from ebay and reset the computer. I drove it around until it completed the drive cycles (maybe 1 or 2 days) and then took it immediately to get emissions/inspection. It passed, but less than a week later the light came on, and you guessed it: P0420.
  • I push this car hard, and occasionally (for example, at 80mph with the gas pedal floored and engine wound kinda high) there'll be this hesitation which my only slightly-knowledgeable head says is detonation and/or the computer fiddling with the timing as it detects detonation/lean. That could be related to the P0171. This is just a slightly-educated guess, and what I'm getting at here is that the P0171 may be a secondary result of whatever is causing the P0420 (remember, the P0171 isn't always present, but the P0420 is always present).
  • I get probably one or two drops of oil when i park it and top off the oil with a quart probably every 2 months. I'm guessing with the small amount of oil that it leaks that I might be burning some oil too, but not enough to be obvious from the exhaust (maybe a year and a half ago I checked and had good compression in every cylinder). I include this because my understanding is that oil can foul O2 sensors and cats.
  • I can occasionally smell antifreeze on a hot day after I park it and every two to three months I add a bit of coolant to top it off. I include this because my understanding is that antifreeze can foul O2 sensors and cats.
  • My $40 code reader also has "live data" capability. So I can see the voltage levels of both O2 sensors. However, ... I don't know what they should be or how they should bounce around, and also the values only update about once a second and it isn't clear to me if that's fast enough to be useful. Further, it just gives numbers and doesn't plot--not sure if that's what's really needed to useful or not.
This coming weekend I want to take care of this. My goal is the same as last time: get emissions/inspection passed so I can drive it for 6 more months. I have another cat ($140 amazon, but actually has positive reviews) and both O2 sensors.
I'm thinking of just replacing the O2 sensors and then trying to complete the drive cycle to see if that fixes the issue (pretty sure the P0420 gets set in like 5 minutes, well before all drive cycles are complete). And then if that doesn't take care of the problem then replacing the 2 year old catalytic converter.
Is this a reasonable approach? Too much, too little? I don't currently have an extra car for trips to Autozone/O'Reilly's/Advance Auto and want to have parts I might need on-hand. Anything I might be missing?
Anybody know what I should be seeing with the O2 sensor voltage levels? Or know of a good source you can point me to on that?
Thanks so much,
nato
Re: Plan for solving P0420?
P0420 = bad cat 99% of the time. The code itself says the o2 sensor is working, as it detected the converter is below efficiency thresholds.
P0171 = intake manifold gasket most of the time...could be a vacuum leak, but usually intake manifold gasket.
Replacing o2 sensors is pointless.
If you are burning oil, it can cause your cat to go bad.
The first o2 sensor should be a nice wave. The second one should remain relatively flat, until you step on the throttle, and then you should start seeing it wave too.
nato
Post by nato »
zbyers wrote: ↑Mon Apr 12, 2021 11:28 am P0420 = bad cat 99% of the time. The code itself says the o2 sensor is working, as it detected the converter is below efficiency thresholds.
OK, I just got done replacing the cat. I cleared the codes and took it for a test drive. Less than 5 minutes in and I have a pending P0420. Anybody got suggestions for the next most likely culprit?
zbyers wrote: ↑Mon Apr 12, 2021 11:28 am P0171 = intake manifold gasket most of the time...could be a vacuum leak, but usually intake manifold gasket.
OK, that's believable. I plan to leave it be for now and not bother with this unless that code comes back.
zbyers wrote: ↑Mon Apr 12, 2021 11:28 am The first o2 sensor should be a nice wave. The second one should remain relatively flat, until you step on the throttle, and then you should start seeing it wave too.
So a "wave", as in a sinusoidal pattern? Or if not really pretty, at least going up and down continually?
What sort of bias/offset should I expect for each of them?
How about ballpark minimum and maximum values?
And what type of period are we talking about--that is, how often does the cycle repeat?
Will I even be able to make this out with the reader I described that updates the voltage values about once a second?
Thank you all in advance for your wisdom and taking the time to respond,
nato
nato
Re: P0420 after catalytic converter replacement
Post by nato »
OK, so it turns out that my code reader does have the option to plot a graph of a single parameter. I spent some time this morning getting plots of the O2 sensors. I'd appreciate it if someone could tell me what these plots suggest, although admittedly I'll most likely have replaced the sensors before I get a reply as I'm anxious since my car currently has expired tags.
The following is the upstream sensor while accelerating at a moderate rate:
The following is the downstream sensor while accelerating at a moderate rate:
The following is the upstream sensor. The first third or so is idling at a stop sign. The second third is accelerating at a moderate rate. The third third is coasting.
The following is the downstream sensor. The first third or so is idling at a stop sign. The second third is accelerating at a moderate rate. The third third is coasting.
Thanks so much in advance for any other suggestions on getting my car fixed,
nato
nato
Post by nato »
tldr: I replaced the catalytic converter, both O2 sensors, intake manifold gasket, and spark plugs. I still have P0420. Please help!
I replaced the upstream O2 sensor, reset the computer, and went for a test drive. The P0420 appears in the pending list after 5 minutes of driving.
I replaced the downstream O2 sensor, reset the computer, and went for a test drive. The P0420 appears in the pending list after 5 minutes of driving.
I believe these were the original (271K miles) sensors. Upstream sensor is on the left; downstream sensor on the right:
I already had the intake manifold gasket on hand and figured it wouldn't hurt to replace it since it's gotta be done sometime anyways. Maybe it's the culprit? ... Nope! :( While I was at it I replaced the spark plugs. I reset the computer and went for a test drive. The P0420 appears in the pending list after 5 minutes of driving.
Anybody have any ideas I should consider for my next step to fix the P0420?
Spark plugs in cylinder order (left is cylinder 1; right is cylinder 4):
Mark
Re: P0420 remains after catalytic converter, O2 sensors, and other parts replaced
Post by Mark »
https://www.autozone.com/ignition-tune- ... 720805_0_0
That's what I've done on Corolla and one Vibe, no more P0420.
nato
Post by nato »
Mark wrote: ↑Sun Apr 18, 2021 8:58 am https://www.autozone.com/ignition-tune- ... 720805_0_0
Thank you so much for the reply! I'll give this a try.
Edit: OK, I see elsewhere in the forum and a reference to another forum on how to do this. Looks like the preferred way is to use two extenders daisy-chained together. The extender closer to the sensor has its bottom (half opposite from sensor) drilled out to allow for the sensor end to fit. This is to be used for the downstream sensor and not the upstream sensor. Anybody feel free to correct me if you have other information or if I misunderstood
Thanks again!
nato
Mark
Post by Mark »
Nope, you got it right. This probably won't pass a visual inspection, but if they are just looking for codes it will solve your problem.
I've found that I have to start with a small drill bit and gradually work my way up to 1/2".
nato
Post by nato »
Whoa! The non-fouler trick may have "fixed" the car.
I've driven the car three times so far, for at least 40 minutes total drive time. No set codes, no pending codes, catalytic converter and O2 sensor drive cycle monitors are showing ready.
The evaporative system monitor is the only thing missing, and I read something yesterday that suggests I might even be able to pass emission test without it here (in Missouri). I plan to take it to get tested as soon as possible and will update this thread with the results.
For future reference I've included information and images following.
I believe the link to the non-fouler above is for non-fouler that won't work for this O2 sensor. The link points to the Dorman 42006 which lists a 14mm thread size (outside diameter of theads). I have the Dorman 42009 which has 18mm threads and fits my catalytic converter assembly's pipe hole and O2 sensor after one of the non-foulers was modified.
I drilled the hole out of one of the non-foulers. There's a small hole and then the inside diameter of the body of the non-fouler is larger than the small hole--both get drilled as the drilled hole was larger than the inside diameter of the body. I used oil to help the bits cut the steel and I used 5 or 6 bits ramping the size up a bit each time. I used a wrench to center the non-fouler on the drill press plate
The unthreaded portion of the O2 sensor that slips into this drilled out portion of the non-fouler has a diameter that is somewhere under 0.48". My final, largest bit used had a diameter of about 0.48".
Threading an O2 sensor into the first non-fouler one can see that the tip of the O2 sensor comes nearly flush with the end of the non-fouler.
I threaded the modified non-fouler into the other unmodified non-fouler.
I saw elsewhere that suggested some applications of this method doesn't work using both non-foulers and suggest not using adding the unmodified non-fouler onto the assembly that'll be screwed into the catalytic converter assembly's pipe hole. I planned to try removing the additional unmodified non-fouler and use only the modified one if the two non-fouler application didn't prevent the P0420 codes. We'll see how this goes.
Note that I used the crush washer/metal gasket on the end of this assembly when screwing it into the catalytic converter assembly's pipe hole and the crush washer/metal gasket end up being crushed non-uniformly. If I wasn't so lazy I would've backed the assembly out and used the assembly without one. In the end it probably won't make much difference either way.
Thanks again!
nato
Mark
Post by Mark »
nato wrote: ↑Sun Apr 18, 2021 9:01 pm Whoa! The non-fouler trick may have "fixed" the car.
Sorry, I couldn't remember what size I used, so I just grabbed the first one when I searched on AutoZone.
A drill press would have made it so much easier and faster. Glad to hear it worked for you, it's a lot cheaper than a new cat and O2 sensors, for sure.
nato
Post by nato »
OK, my P0420 issue is finally resolved. All OBD2 readiness monitors passed by this morning, I was able to get an official smog test pass today and get the tag to prove I payed my taxes.
See the previous post for details, but the highlights are:
1. Replacing the catalytic converter, both oxygen sensors, intake manifold gasket (primarily due to another code that I'd dealt with), and the spark plugs didn't fix the P0420 issue.
2. After doing all of the above I added two spark plug non-foulers (after modifying one of them) between the catalytic converter assembly's pipe and the downstream oxygen sensor. This fixed the P0420 issue.
So just shooting from the hip here: By extending the distance between the oxygen sensor and the catalytic converter itself the speed at which the sensor measures the temperatures is probably slowed down. It might also be attenuated as the ambient air might keep it from reaching as high of temperatures as it was before. If this is what's going on then it would seem that one or more of the following is true:
  • The OBD2 catalytic converter monitor is improperly tuned, and/or
  • The previous two catalytic converters I've had along with the current catalytic converter are all out of spec, and/or
  • The previous oxygen sensor and current oxygen sensor are both out of spec.
The last two reasons seem quite unlikely as they rely on having multiple failures, including failures of brand new parts. The fact that a number of folks have used the non-fouler installation method successfully to be rid of the P0420 error seems to corroborate the hypothesis of an incorrectly tuned OBD2 system. Of course, there's no way to really know for sure as there's no way to know what's going on inside the ECU.
IANAL, but I'm pretty sure what I did was illegal. As far as I understand, it'd be literally impossible to have legally fixed the issue so I could renew the registration (which is required to legally drive the car). I could spend some time now ranting about the injustice of a federal regulation that levies expensive requirements on the little guy while the regulation is configured such that it disallows independent verification (because of proprietary/closed source software and corporate "secrets"). I could also rant how the same baloney allowed Volkswagen to get away with their emissions scandal for at lease 17 years, and how others in the know have revealed that Volkswagen isn't the only manufacturer that cheats on emissions, and that it's just that they're the only one that's been caught as nearly every other manufacturer pulls the same sorts of baloney. I could complain about it, but I'm not going to.
Maybe I'm just full of baloney.
I'd like to offer huge thanks to Mark and zbyers for their help!
nato
nato
Re: SOLVED: P0420 remains after catalytic converter, O2 sensors, and other parts replaced
Post by nato »
OK, here I am two weeks later and the code is back. Admittedly, I was pushing it really hard--accelerating really hard up to 90mph driving on the interstate this morning. At some point I was at a stop light and noticed the engine light was on. I had the scanner in the glove compartment; connected it and saw I had a P0420 active code and a P0420 pending code.
<sigh>
Mark
Re: Unrelenting P0420 remains after catalytic converter, O2 sensors, and other parts replaced and modified
Post by Mark »
Well that sucks. Hope you're right and it was just due to pushing it hard. I would just clear it and see how it goes, but the important thing is that you passed emissions. So at this point the CEL is mainly just an annoyance.
lexicon
Post by lexicon »
Thanks for the tip and the discussion, but, how does this affect the actual operation of the vehicle ? Great that it passes emsissions, but how does the engine computer now change settings to accomodate for the "new" data sent by the post O2 sensor... does it compensate by running too rich or lean ?
Thanks
2005 VibeAutomaticStockNon AWD125 hp model
lexicon wrote: ↑Wed Oct 27, 2021 1:31 am Thanks for the tip and the discussion, but, how does this affect the actual operation of the vehicle ? Great that it passes emsissions, but how does the engine computer now change settings to accomodate for the "new" data sent by the post O2 sensor... does it compensate by running too rich or lean ?
Thanks
the computer has no idea as it thinks the sensor is reading the correct airflow and runs as it should.
Danzvibe1
Post by Danzvibe1 »
I gave up on this problem over two years ago. Been running with the light on the whole time. The main irritation is a rough idle. Other than that drives just fine.
I'm interested in finding an answer though. I just can't believe there's not more info on this problem...
what brand converter did you end up using? if some cheapo off brand from ebay or amazon, there's your answer.
For a Toyota, anything other then a OEM converter is a risky "roll of the dice" if it is going to work for this code. If it is a high mileage car, there is so many other things that can cause this code in a Toyota. Everything wears out and can all add up to producing this code, not just the converter.
Have you done a search in this forum about this issue? I remember there was a post here about adding a resistor in line to help produce the voltage drop that the software is looking for. This does not fix the issue, but for an old car that is not worth much, you do not want to spend a lot of money on it.
Thanks
Theoretically,
The upstream O2 sensor is used by the computer to monitor/track fuel/air mixture. The second O2 sensor is after the cat, and its only purpose to to measure the output of the cat. The computer compares the readings from the two O2 sensors, and it hopes to find the the downstream one measures less than the upstream one, indicating the cat is converting. If it sees the two O2 sensor readings too close, it throws a P0420. If the computer senses some other problem with the O2 sensors, such as no output, it is supposed to throw a different code.
That's the way it's supposed to work. Sounds like nato's Vibe is misbehaving for some obscure reason that I can't think of any advice to offer.
Bookworm
Post by Bookworm »
The place I've bought cats in the past is listed in one of these threads. If you search for my name, plus 'catalytic converters', you'll find it.
I had excellent service from them, and the aftermarket cat wasn't cheap, but it was nowhere near dealership prices. That one lasted in my 03 vibe about 120k (before passing it on, still working)
FrankenVibe
Post by FrankenVibe »
For anyone looking into this in the future, they sell an O2 sensor defouler (anti fouler) that doesn’t need drilling or modification of any kind. They’re extra long, so just a direct fit (thanks CraftsmanQuad19). I went with Big Daddy Garage, I’ll advise if I have any issue with it.
Here’s the thread where it was discussed:
viewtopic.php?p=533412#p533412
Glssonion1
Post by Glssonion1 »
zbyers wrote: ↑Wed Nov 10, 2021 3:59 am what brand converter did you end up using? if some cheapo off brand from ebay or amazon, there's your answer.
^^^ I'll add to this ..
The issue is probably not likely a cheapo converter (though it's kind of partially true). Let me explain.
There are two types of emissions standards on cars sold in the United States. There is federal emissions standard, and California emissions standards. Now California emissions standards eventually more or less became federal emissions standards, as most cars sold in the US circa 03-04ish were upgraded to California emissions standards. If you look under your hood you're vehicle should be badged somewhere with the emissions standards per that vehicles ECU. If your car says California emissions standards, you absolutely positively without a doubt need a California emissions catalyst. I'm guessing that the 140$ eBay cat you bought is not rated for California emissions. Most California emissions catalysts that are after market start at 600$ and work their way up. There's more precious metals in a California emissions catalyst than there are in a federal emissions catalyst. Your vehicles ECU is set to read a much tighter level of emissions tolerance than the federal emissions catalyst. If you put a cheap federal emissions cat in a California emissions vehicle, it can be brand spanking new, and it will still throw a p0420.
It's fucked up, because most after market cat companies simply state on their products "this catalyst cannot be sold in California, Maine, etc etc". This is true, but it's also misleading, because 95% of the vehicles manufactured post 05 are programmed on Cali emissions. So even though you might not live in a state where the 140$ after market catalyst youre buying is illegal to buy, it doesn't mean you can still put it in your vehicle without a cel popping up.
Now you can try to do any number of workaroubds, but ultimately the only way to get that p0420 code to shut off, is to upgrade that catalyst to one that is California emissions standard compliant. The only other alternative, is to flash a new map into the vehicles ECU, which has the p0420 code disabled. (Many custom tuner guys do this, to run catless.) I did this very thing myself in my legacy gt.
So in a round about way he's right- your cheap catalyst is probably the culprit. You don't necessarily need to buy one from Toyota. You just need to make sure that whatever you buy is Cali compliant.
Glssonion1 wrote: ↑Wed Aug 24, 2022 9:49 am
It's hardly anything to do with Cali compliant. It's more so that the cheapos on eBay or Amazon simply do not meet ANY specific emissions standards. There also are no tunes available for the Vibe unless you do a standalone ECU, which is even more expensive. O2 sensor defoulers also exist to trick the readings of the sensor. No matter what workaround, the ultimate cause is the cheap aftermarket cat.
There is a reason those cats on eBay/Amazon run so cheap; they lack the majority of the precious metals needed for a cat to work.
FrankenVibe
FrankenVibe wrote: ↑Wed Mar 30, 2022 8:54 am For anyone looking into this in the future, they sell an O2 sensor defouler (anti fouler) that doesn’t need drilling or modification of any kind. They’re extra long, so just a direct fit (thanks CraftsmanQuad19). I went with Big Daddy Garage, I’ll advise if I have any issue with it.
Update:
This fixed worked perfectly fine until the car was totaled a little over a year ago. I got another vibe and am going to try taking this part off of the old vibe and putting it into the new one.
beyondcashed
Post by beyondcashed »
April 24, 2025
Car: 2016 Kia Soul 1.6L + P0420
::Story Time, If u dont want to read through, the moral of story is, a C.A.R.B Certified Catalytic Converter solved my problem::
This whole post has been very valuable to me since ive been trying to deal with this P0420 for the last few months. ive been driving with it for over a year and now its time to do emissions so i can renew my tags. My story goes through all the different things.
Tried acetone with half tank of gas. i think it cleared the code for a little while. then as it got closer to end date (tags expiring) i started researching what i could do and not break the bank. I purchased a cat on amazon from excel exhaust. it was $190 on their website but $94 on amazon so i picked it up. paid a facebook mechanic to install for $180. it didnt clear my P0420 code. and my exhaust smelled bad now. so it was a complete hunk of junk. i got my money back from amazon. did a bunch of online research. eventually went to an exhaust place. Guy gave me the run around said I should never buy cheap cats they wont get u through a P0420. so i saved up more money still not knowing the true issue.
Then i found my dads old mechanic who he thought had passed away. but i found him in the old neighborhood in a different location. Mario the mechanic was the first person to point out the "Vehicle Emission Control Information" tag under my hood. it says "California: ULEV II PC OBD: CA II"
so in short. if you try to install a cat that isn't "California regulated" aka "C.A.R.B" certified for your car that requires it, u probably wont get rid of your P0420 because your ECU is expecting California emissions standards after the exhaust passes through the cat into the 2nd 02 sensor"
I got my money back on the crappy cat. but i lost the initial $180 i paid mechanic to replace it. because i had to pay him twice. turns out he cost me more money because he apparently forced my o2 sensor in crooked which stripped it, and i had to pay mechanic $20 to use torch to get it out just to find out it wouldnt be able to be used again. and had to drop $199 on another o2 sensor. On top of all of that. the kid at Mario's. after helping me put new o2 sensor in the new "carb certified" cat i told him to reset the codes. so he unplugs battery for a bit and plugs in the obd tool turns car on and clears codes but then keeps telling me the P0420 is still showing.
I was pissed but in back of head thinking "shouldn't i drive around for a while so the car can recognize the cat?"...So as i drove away now having spent $800 on cat, install, and new 02 sensor i was utterly pissed. (even though the check engine was off) but ive reset the codes before and after 20-30 mins the check engine would normally come back on so i assumed it would come back on. I went home. the next morning i did a delivery run with amazon flex and code was still off. i told myself if i make it to end of shift and theirs no code then it finally worked.
It finally happened! The P0420 is finally gone! I went to emissions first thing in morning and passed with flying colors. and can now renew my tags. I figured i would try the o2 sensor spacer trick but the kid was telling me i could have a vacuum leak and I was worried the 02 spacers would do nothing.
Thankfully I didn't have to deal with that. I got a Walker Carb Certified cat from Carparts .com for my car year make model, paid facebook mechanic to come to my house to install it for a deal. He did do a good job just kinda mad he forced my OE 02 sensor into the cheap cat which cost me money, but i could have avoided that if i knew about my cars VEC information sheet under the hood which would have told me I have to have a Carb certified cat or my ecu wont like it.
Moral of the story the guy who mentioned this "Glssosion" was right on point for me. Mario the mechanic mentioned I needed a California cat and that it was expensive. I figured he meant Carb certified but he didnt know what that was. weird coming from a muffler mechanic but it is Arizona.
So i found an "aftermarket" cat from Walker for around $480 or something i got the 3 year warranty and got it shipped to my house. on kia car parts website they wanted $1009 which i guess is reasonable for cats. The Magnaflow one was $1020 i had saved up enough and was going to pull the trigger on one of those when i found the Walker carb certified 50 states on carparts .com, and it worked for my 2016 kia soul 1.6L with California: ULEV II PC just sucks i had to spend $199 at autozone after tax for 02 sensor, cuz i needed to get it fixed that day so i could be back on road. otherwise i would have ordered a Bosch OE o2 sensor online for like $140 after tax. Just so happy this bs is finally over. It felt like i was never going to get rid of this code. I drive for a living and at end of month my tags expire. right down to the wire i passed emissions and will be good again for a while. Always check under your hood for newer cars cuz u never know if u need a Cali Cat. 8-)
