Uses for the AC (2-prong outlet)?
tots
Post by tots »
Just wondering what (or if) folks are using the Vibe's AC outlet for? Laptops seem like an obvious use, but is enough power produced to run say a blender, or a vacumn? The outlet seems like a neat idea when you 1st hear about it, I'm not sure if there are many uses for it in practice. (?)
My Vibe: 2004 Base, Fusion Orange, Mono, ABS, Power.16" Alloys, Factory Alarm, Side Air Bags. Cargo Box
Kari
Re: Uses for the AC (2-prong outlet)? (tots)
Post by Kari »
I haven't used mine at all. I've considered using it to vacuum the car out, but then for some reason I've never done it.
GenVibe Global Moderator
This is not the standard search before starting a new topic blast, but a happy helpful tip that there was a previous discussion on this is at What are people plugging into their standard power outlet? This reply is invisible
Re: Uses for the AC (Salsa!)
Should be able to run a blender...they had a commercial that showed them using a blender...
disneydj
Re: Uses for the AC (ragingfish)
Post by disneydj »
Call me crazy, but I swear we had this conversation before... and if I remember correctly it went on and on and on... Maybe I should run out the the car, make a smoothie and try to remember... oh wait here it is http://forums.genvibe.com/zerothread?id=193/
Re: Uses for the AC (disneydj)
your link is screwed up disney:http://forums.genvibe.com/zerothread?id=193
redlava
Post by redlava »
I tried using a dirt devil vacuum when I first got my car in march, and it worked for about 2 seconds, then the breaker tripped. Haven't tried anything since.
