Why can't I insert a picture in my text
robdog
Post by robdog »
How do you insert pictures here. i click on browse and insert my file and then save it and the picture does not show up. why is this
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
robdog
Re: Why can't I insert a picture in my text (Salsa!)
Post by robdog »
the underlined message does not appear. no link to a photo appears
Re: Why can't I insert a picture in my text (robdog)
quote:How do you insert pictures here. i click on browse and insert my file and then save it and the picture does not show up. why is thisWhat do you mean by "insert my file"? What I do is hit the Browse button, which pops up a file selection window. I use that to select the file to upload. Can be any kind of file, as long as it's smaller than 3 MB.
robdog
Post by robdog »
it is a jpg and it is only 1mb. It just doesn't take it for some reason.
NovaResource
Post by NovaResource »
You have to have the picture on the Internet somewhere, not just your hard drive. Add the picture as an attachment to a post and then you can display it.
cohocarl
Post by cohocarl »
quote:it is a jpg and it is only 1mb.The forum software says "The file cannot be larger than 3000000 bytes" or 3mb, but I'm wondering if the text is wrong and it should be 300k. Try opening it up in PaintShop or whatever graphic software you use and reduce the image quality, then save it again. A 1mb picture is way too large for someone with a dial-up connection.This pic is only 36k, and it's still relatively sharp.
Re: Why can't I insert a picture in my text (cohocarl)
as a dialup modem user, I know that there have been some really large pictures uploaded, well beyond 300K (that's why I have them turned off)
cohocarl
Re: Why can't I insert a picture in my text (NovaResource)
Post by cohocarl »
quote:You have to have the picture on the Internet somewhere, not just your hard drive.I just do the "file attachment" from a pic on my H.D., post it, then go back to the post and "copy shortcut" from the attachment, edit the post and "paste" it between the [img][/img]. Before Genvibe had the "file attachment" feature, I had to post pics on my personal web space with my internet provider, then pull them from there, but I just do the "file attachment" deal now.
Herb
Post by Herb »
Don't mind me, I'm just trying it out myself to see if it works or not.
NovaResource
Re: Why can't I insert a picture in my text (Herb)
You typed it like this:[img]http://forums.genvibe.com/antbase2.jpg[/img]It should be:[img]http://forums.genvibe.com/zerofile/2148/antbase2.jpg[/img]See:
I had the forum do that to me once...I tried to attach a PDF and it just wouldn't take it, but it was only a meg...It's temperamental sometimes...If you want, I'll host it for you on my server and send you the link...just e-mail me at the address in my profile and attach the file...
Re: Why can't I insert a picture in my text (ragingfish)
I think he was trying to post a pic in http://forums.genvibe.com/zerothread?id=5977 and it looks like ihe did it, now just needs to edit the post to correct the inline from C:Documents to put http://forums.genvibe.com/zerofile/2146/redlinejpg.bmp between the [IMG][/IMG] tags, like Although, I must point out that a bmp makes for a big file. Here it is as a jpeg, 40K instead of 518K.
quote:You typed it like this:[img]http://forums.genvibe.com/antbase2.jpg[/img]It should be:[img]http://forums.genvibe.com/zerofile/2148/antbase2.jpg[/img]Scott, I was going to ask you how you got the img and url to show up without being interpreted, but when I quoted your post I see you put bold/end bold tags in the img brackets, so they don't show up but keep the img tag from being interpreted literally. Pretty crafty
Vibe Rater
Post by Vibe Rater »
Does your ISP allow you to have any webspace? You need to setup your webspace first, then you must upload the image file to your webspace using an FTP program, like Bulletproof. Then you need to link the image file from your webspace to this web board. For example, if you were with Rogers ISP and your username was Robdog and the filename was 'robdog.jpg' you would need to type between the [IMG] [IMG] the following.http://members.rogers.com/Robdog/robdog.jpg .Then the picture would show up on the board. Like This:
cohocarl
Re: Why can't I insert a picture in my text (Vibe Rater)
Post by cohocarl »
Want to give yourself a headache???? Right click on the above image and "set as background". Makes really annoying wallpaper.
NovaResource
Re: Why can't I insert a picture in my text (joatmon)
quote:Scott, I was going to ask you how you got the img and url to show up without being interpreted, but when I quoted your post I see you put bold/end bold tags in the img brackets, so they don't show up but keep the img tag from being interpreted literally. Pretty crafty Thanks, people are always telling me I'm a Fart Smella. Doh! I mean, Smart Fella.
