How do you get to the spark plugs?
vibenorth
Post by vibenorth »
I changed my oil the other day and thought I'd take a look at the spark plugs, and realized I wasn't sure how to get to them. I couldn't find any info in the manual.
Re: How do you get to the spark plugs? (vibenorth)
There's a thread that has some good pics of the spark plug access at http://forums.genvibe.com/zerothread?id=5814, and an ongoing discussion of which plugs are best for a Vibe.It's different than other cars I've had.
champcaracing
Post by champcaracing »
both engines you will need to remove the engine cover (black plastic) should be 2 10mm nuts in front and 2 plastic clips in the rear (1ZZ engine) the 2ZZ .....should be 4, then unplug the coil packs, remove the 10mm bolt. and you now have access to the plug.
vibenorth
Re: How do you get to the spark plugs? (champcaracing)
Post by vibenorth »
How are the clips removed?
engine1
Post by engine1 »
Just use a small bladed screwdriver to pry up the center then it can gently popped out of the cover1
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
champcaracing
i lift the cover up in front and sorta roll the cover back...SLOWLY not to break the clips. i have used the screw driver before and break them sometimes.
