I dropped a screwdriver into the intake
petervivian
Post by petervivian »
Hello, everyone. Happy holiday!
Today I accidentally dropped a screwdriver into the intake manifold. :D
My original plan was just to clean and re-oil the filter, clean the MAF sensor and throttle body. I inserted a screwdriver UNDER the throttle plate and went to get the cleaner. When I came back the screwdriver is gone. It must have fallen into the intake.
Now I have to remove the intake manifold to pull the screwdriver out, right? I also have to change the gasket during the removal since it is still the original one, right?
By the way, where can I get a quality gasket at a good price?
Thank you and happy holiday.
Derf
Re: I dropped a screwdriver into the intake
Post by Derf »
Unless you can get to the screwdriver with a magnet. The intake is not that hard to remove, several write ups on this forum. Feedback is the Toyota Matrix gasket is better (orange color) Part for 2003-2008 Base, GT uses a different gasket.
http://www.rockauto.com/en/moreinfo.php ... 62&jsn=648
Otherwise this gasket fits OEM
http://www.rockauto.com/en/moreinfo.php ... 59&jsn=463
Replacing the intake gasket can be thought of as preventative maintenance. Several higher mileage vibes have reported an intake gasket leak that leads to lean engine codes.
ImUrOBGYN
Post by ImUrOBGYN »
Same thing I was thinking, magnet. Either one of the various magnet tools or a good magnet on a string... a strong string. haha
And since you didn't see the screwdriver fall in, are you absolutely sure it didn't fall and wedge itself elsewhere or somebody else didn't screw with it?
Good luck and let us know how it goes.
JerBear
Post by JerBear »
ImUrOBGYN wrote:Same thing I was thinking, magnet. Either one of the various magnet tools or a good magnet on a string... a strong string. haha
This is a far more likely scenario, unless the screwdriver was very small the majority of its weight would have been outside of the hole it was in. Take a flashlight and look carefully before removing the intake. However, the intake gasket is a good idea to replace anyway if you have a few miles on it.
petervivian
Thank you for the replies. I was able to get the scredriver out with a magnetic pick tool.
The screwdriver is not very small. I am suprised it did slide down the intake (that leads to the 2nd piston?).
After lying in the intake for one day, some oil ate into the clear plastic handle and turned it to brown color (see picture).
What might be cause of the oil in the intake manifold?
Thank you.
Derf
Post by Derf »
Stuck or failing PCV valve could let oil into the intake.
I agree with Derf. It also most certainly means that the intake manifold gasket is bad or going bad.
