Sc specs and price.
goodvibe
Sc specs and price.
Post by goodvibe »
Here's a link to another forum with good info on the SC. http://www.matrixvibe.net/forums/viewtopic.php?t=3567 Feel free to delete if there's a sponsor issue. + 20lb torque + 36hp Retail's probably $2995 before labor. The lower price here may help you negotiate with your dealer.
AKLGT
Re: Sc specs and price. (goodvibe)
Post by AKLGT »
believe it only works for the matrix. the ecu computers require GM's.
AKLGT1998 Subaru 2.5RS
KSNeptune
Post by KSNeptune »
Lower HP and torque than first hinted at. Makes me wonder if they've lowered the specs in reality to make the unit more reliable, or lowered the specs on paper only, to make the unit seem less dangerous and as such less of a cost to insure.Time will tell. First person to get on, please get it dyno'd. Before and after, too. Then post the specs here.KSNeptune
goodvibe
Re: Sc specs and price. (trdvibe)
Post by goodvibe »
Granted but specs and price should be the same. It'a not for me. Just good to know what's up.
NovaResource
Post by NovaResource »
quote:The new 1.8L Supercharger offers up to a 35% increase in power and torque... Peak torque is 145 lb.-ft. supercharged @ 4000 RPM vs. 125 lb.-ft. stock at 4200 RPM. Peak horsepower is 166 HP supercharged @ 6800 RPM vs. 130 HP @ 6000 RPM.125-tq + 35% = 168.75130-hp + 35% = 175.50Those numbers not match up to me.145-tq - 125-tq = 20-tq increase20-tq / 125-tq = 16% not 35% That's less than half! 166-hp - 130-hp = 36-hp increase36-hp / 130-hp = 27% not 35% Someone at TRD needs a math class.Also, what's with the 6800-rpm rating?! Does that mean the 1ZZ will get an additional 400-rpm (or more) range of power?How much do GT's go for again?Not a happy camper. Here's to hoping those number are underrated so not to steal sales away from the GT/XRS.
Larry
Re: Sc specs and price. (NovaResource)
Post by Larry »
quote:The new 1.8L Supercharger offers up to a 35% increase in power and torque... Peak torque is 145 lb.-ft. supercharged @ 4000 RPM vs. 125 lb.-ft. stock at 4200 RPM. Peak horsepower is 166 HP supercharged @ 6800 RPM vs. 130 HP @ 6000 RPM.125-tq + 35% = 168.75130-hp + 35% = 175.50Those numbers not match up to me.145-tq - 125-tq = 20-tq increase20-tq / 125-tq = 16% not 35% That's less than half! 166-hp - 130-hp = 36-hp increase36-hp / 130-hp = 27% not 35% Someone at TRD needs a math class.Also, what's with the 6800-rpm rating?! Does that mean the 1ZZ will get an additional 400-rpm (or more) range of power?How much do GT's go for again?Not a happy camper. Here's to hoping those number are underrated so not to steal sales away from the GT/XRS.They have to be inaccurate IMO. Boost is boost. Does 1 pound of boost only increase hp by 4.8? I doubt it. I called TRD and went over the numbers and he agreed that they don't seem right. I'm guessing they're either quoting wheel hp numbers or they made an error. If there is not an error, it's misleading advertising. He did say it takes 2 seconds of the 0-60 mph time. If that's correct, it's pretty amazing to knock off 2 seconds with such a modest increase in torque and hp.
MonotoneSatellite
Post by MonotoneSatellite »
I should have seen this coming. The SC for the Sunfire/Cavi boosts them up to about 190-hp according to the specs on the GM/Goodwrench site. I think the Sunfire 2.4 puts down about 150-hp before the SC which is a 40-hp or 26.666% increase in power.http://www.gmgoodwrench.com/gmgoodwrenc ... 498287Damn, that sux. If those #'s hold true, I think I will move to a turbo or the GT. However, I do like my warranty. The biggest problem with the SC at those numbers is the cost.2004 Base Vibe $17,045 + SC $3000 + Install $500 =$20,545 166-hp/145-tq2004 GT Vibe $19,995 180-hp/130-tqI will not pay more for less. Simply put if the does not beat the GT, I will not buy it. At this point GM has my money for my Vibe. But I'll be damned if they will get more.
Larry
Post by Larry »
Just an update. TRD is saying the 35% increase is inthe lower rpms. If that's the case, it must be pretty fast off the line.
NovaResource
Re: Sc specs and price. (Larry)
quote:Just an update. TRD is saying the 35% increase is inthe lower rpms. If that's the case, it must be pretty fast off the line.OK, I'll accept that explination. Just because the peaks aren't 35% higher doesn't mean there isn't a 35% increase in other areas on the HP and TQ graph. I'd like to see graphs of the HP and TQ before and after the S/C install.If their claim of a 2 second decrease in 0-60 is correct that would equal at least a 2 second decrease in the ET. That would put me in the mid to high 14 second range in the quarter. That I like.
goodvibe
Post by goodvibe »
Thats asking a lot but even 1 sec would feel great and I bet it will still be a kick to drive. They might be consentrating on the low rpm to give the most performance without stressing the trannys with high peak power. The numbers also seem low to me even without an intercooler. Maybe the advance is knocked back more with the hotter expanded air. Beats me.
Faultline
Post by Faultline »
quote: I'm guessing they're either quoting wheel hp This Is my bet. has any one dynoed their vibe to be 116whp??+ 50hp = 166whp.....like 130hp + 50hp = 180hp at the crank..somebody took the dyno from the SC car's whp...and compared specs to the factory crank rating... and my hospe is that it was done on an automatic..
AKLGT
Re: Sc specs and price. (Faultline)
Post by AKLGT »
i would love to drive a s/c base manual and compare the diffs b/w it and my GT. what fun!
goodvibe
Post by goodvibe »
Those are TRDs added HP numbers compared to stock ay the crank. They may be conservative but I'm sure they're all at the crank.
Flip-Side
Post by Flip-Side »
quote:Not a happy camper. Here's to hoping those number are underrated so not to steal sales away from the GT/XRS.Lets stop going off of a friends roommates brothers uncles sister-in-law "that works for gm". What will be will be. I for one still think the SC vibe will have about 180 hp as long as the psi is the same. Then again, the ol' GM 3800 v6 was 200hp and only 240hp with the SC in the riviera or bonneville. They were busting cranks at 270hp, so they had to bring it down.
Larry
Post by Larry »
redtrdmatrix
Re: Sc specs and price. (silverawd26)
Post by redtrdmatrix »
A turbo is beginning to look better everytime I think about how cra!@#y the specs on this S/C are
03 Radiant Red Matrix XR 5speed with sport package and factory 17'sMods:TRD Sport MufflerTRD Strut Tower BarTRD GrilleInjen CAIMOMO Tomahawk shift knobTEIN springsSilverstar lows, highs and fogsAlpine CDA 7892 headunitInfinity Reference 625i speakers
There''s a lot of SC talk over at matrixowners, and hopefully one of the first to get the SC will get a before and after dyno, so that there will be actual independent data on the performance gains
satur9
Re: Sc specs and price. (joatmon)
Post by satur9 »
whatever happened to that peak hp number after redline deal nova spotted something like 6,700rpm im to lazy to look it up
satur9
Re: Sc specs and price. (satur9)
Post by satur9 »
i checked out larrys link it states 15.9 et for the sc and 16.5 for the gt 17.1 stock. personally i like those numbers. it beats a gt here and i know that many of you have got better times than these. but after runing at the track on two different occassions in 80 plus weather i thought my 17.35 best was to pathetic to post but now i feel better.and wont be dissapointed that my sc wont put me in the 14's.(supercharger alone that is!!!)
Faultline
Post by Faultline »
does anyone know if the pontiac version will be cheaper than the TRD? Months ago, TRD was saying 3400 or so, and pontiac was saying "well under 3000 installed" ...so now I have seen TRD offered as low as 2600, does that mean the pontiac SC will be lower? any one know?
