Driver's side wiper won't go all the way to the left
21Rouge
Post by 21Rouge »
I just noticed recently this happening.
And as far as I can tell everything else seems fine regarding this wiper's path across the window.
Any ideas?
Re: Driver's side wiper won't go all the way to the left
How far does it get to the edge of the windshield?
How far down does it go when turned off?
Is there any play in the movement, can you move the arm by hand when the wiper is off?
Do you think it has always done this and you only recently noticed, or do you remember it different before and this is a new development?
If it's just not properly aligned, you should be able to remove the nut, and reposition the arm on the splined shaft
21Rouge
Post by 21Rouge »
joatmon wrote:If it's just not properly aligned, you should be able to remove the nut, and reposition the arm on the splined shaft
Thanks for taking time to respond joatmon.
I did just that and all seems fine.
