MAF sensor cleaning question
basist4
Post by basist4 »
I just changed the oil, and spray cleaned MAF sensor and TB butterfly.
before I was getting 28-31 MPG...after maintenance I have 25 mpg avg on 2 fill-ups.
do I need to pull a fuse to reset ecm or anything like that?
or do I just chalk it up to recent hot/humid weather here on the Gulf Coast?
GaryG92
Re: MAF sensor cleaning question
Post by GaryG92 »
Similar problem here. Once I bought my vibe with 132k miles, I changed the spark plugs, changed the PCV valve, Engine air filter, cabin air filter, and cleaned the MAF, and my MPG remained the same. I figured I'd at least get 1-2 MPG extra. :roll:
Proud Vibe owner as of 6/13/2015
05 Base, 131k miles
Team Lava
Looking forward to many years of good Vibes!
Mark
Post by Mark »
Disconnect your battery for 20-30 minutes to reset the ecm after you clean the MAF, then it can re-learn.
