Adding auto dimming mirror
Sonders
Post by Sonders »
Has anybody added a auto dimming rearview mirror in their Vibe? I'm assuming I can tap into the wires for dome light/moonroof switch? If so how do I get to the wiring for those switches?
2003 Vibe base/moon&tune work commuter
Re: Adding auto dimming mirror
The images are broken, but: viewtopic.php?t=6136" onclick="window.open(this.href);return false;
I did the same sort of install and got power from an add-a-circuit in the instrument panel fuse block and ground from a bolt behind the kick panel trim. Pretty easy install.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
Sonders
Post by Sonders »
Thanks, I'll have to read through that thread.
