Tim, don't worry about it. I used a procedure from an earlier Toyota Matrix I found on the web. The connector on the airbag indicator lamp was different, found a diagram of it though.
I ran through the diagnostic, wiring is good as is the indicator lamp, must be the main airbag computer. Just ordered it.
For future reference, here is a 03-07 Matrix service manual section for the 43 airbag code:
https://worldtracker.org/media/library/ ... 280015.pdf" onclick="window.open(this.href);return false;
Attached is the connector diagram for the airbag indicator light plug. Wires 6 and 7 are P-AB and PAON from what I can tell.
I am going to try using a Toyota part # to see if that module will work instead of the GM sourced module. The one in my car says Toyota on it and has the Toyota part # on it.
Connector
- airbag indicator lamp plug
- 156149435.gif (11.05 KiB) Viewed 5121 times
Airbag module (original)
- my airbag module
- airbagmodule.jpg (72.34 KiB) Viewed 5121 times
2009 Pontiac Vibe, 1.8 auto, stock, 161k miles.
