Correct fluid capacities
zdkaiser
Post by zdkaiser »
Hi all,
I am getting mixed messages about the capacities for a 2007 base Vibe. The manual says it takes 4.4 quarts of oil. Is this correct? I added about 4 quarts and it seems right on.
Also, is the coolant capacity correct in the manual? It says 6.9 quarts.
What about the transmission fluid? What is the total capacity for this vehicle. When I do a drain and fill I get out about 3.75 quarts each time. Whereas others have commented and say they only get about 3.3 quarts out of their vehicles.
So what is the general consensus on these fluids?
Thanks.
Salsa Guy
Re: Correct fluid capacities
Post by Salsa Guy »
I'd suggest you run warm up the engine then recheck the oil. But I've read it's 4.4 quarts.
The coolant sounds right.
The Transmission is because 1/2 the fluid is in the torque convertor. The only way to get it out is to run the engine then drain and refill at the same time.
http://www.youtube.com/watch?v=MsdPAadc9fY" onclick="window.open(this.href);return false;
triz
Post by triz »
http://www.amsoil.com/mygarage/VehicleL ... IAC+VIBE+8
Hope that helps. Always go by what is in your manual. Always check your oil again before starting after a day or two.
plusforce
Post by plusforce »
Toyota revised the oil level for 2003-2005
old oil capacity: 3.9 qrt
new oil capacity 4.4 qrt
new dipstick toyota part# 15301-22050
1ZZ-FE_ENGINE_OIL_LEVEL_SPECIFICATION_UPDATE_T-SB-0134-08.pdf
(167.51 KiB) Downloaded 646 times
Pontiac Vibe 2005/base
