Having several issues since having my clutch replaced...
But regarding this one, I added grounds 8 years ago - this particular ground wire seems to be awfully loose, and I don't remember it connecting where it is now on the transmission. I've had a CEL on for forever (forget the # but it has to do with O2 Bank 1 or Cat or something about the injectors), researched it, a forum post popped up and it stated a loose G103 ground was causing misfire issues in a Cobalt - but also listed the Vibe GT in the comment as well.
http://www.cobaltss.net/forums/problems ... es-105419/ .
I've already done the O2, twice! The Cat is maybe at issue because it's probably near 150,000 miles (High Flow Magnaflow). Hope it's not the injectors but I am over 230,000 miles so who knows. I'm just trying to eliminate the possibles. and that wire just seemed out of place to me.
BTW, my first clutch lasted 214,000 miles. This new one with only 16,500 miles already feels worse than the original did at replacement. Shudders, high pedal engagement. Out of warrantee now. Clutch place told me my flywheel was fine when they replaced the clutch but are now saying the shudder is probably the flywheel. A little perturbed about that.
