Engine Pic Question
tribones
Engine Pic Question
Post by tribones »
Maybe and easy one, but what would the attached pic indicate for header #4?
SeattleJeremy
Re: Engine Pic Question
Post by SeattleJeremy »
Haven't seen that on my car, but I would guess you've got something leaking on that intake manifold tube.
Is it oily or dry?
If it turns out to not be an actual problem, maybe an overzealous oil change guy started cleaning, then got desecrated. :lol:
kumquat
Post by kumquat »
It's too even and location-specific to be anything spraying or leaking. Looks like someone just wiped it down.
It is an indication you need to clean up the remainder of the engine. ;)
Agreed that it seems a bit too even... If someone else changes your oil and they did a sloppy job, that's close to the filler so maybe they had a mess to clean up.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
How's it look under the decorative cover?
Salsa Guy
Post by Salsa Guy »
lannvouivre wrote:How's it look under the decorative cover?
LOL but a good thought. Oil fill is right there, did an oil jockey spill and wipe off the intake runner?
circuitsmith
Post by circuitsmith »
Salsa Guy wrote:did an oil jockey spill and wipe off the intake runner?
That makes the most sense to me.
2006 Matrix 5-sp
leemur
Post by leemur »
Yep...it's a hint. :) Oily rag works good for quick cleaning.
2004 Fusion Orange, bought new R.I.P. 2009 Carbon Grey 2.4, bought new. 2004 Neptune bought used-2013
