First time here so I'm a bit green on this site, been a GM A tech for years got out of the business in 2002 after over 40 years in GM dealers. Bought my daughter a 2009 Vibe, 2.4 auto trans. Yesterday I changed the oil and filter, looked it over saw nothing other than the RF tire was down to 26 lbs and the rest were at 32, tire light was on. I air up all the tires to 35 psi, check for oil leaks and level, park the car in her spot. This morning she gets about 2 miles from home, calls and says all these lights are blinking, she comes home takes her moms car to work. I get in it, sure enough, some light with squiggly lines is blinking, trac light is on and the service engine light is on all at once this happens. I take it for a short drive still blinking, I try the button on the dash for stablitrak and nothing happens or changes. I tried shutting it off and on a few times to no avail. My wife works 5 miles from our home so she takes it to work, calls and said, what lights?? I don't see any lights on. So I go there lunch time to take her to lunch and drive the Vibe, sure enough all the lights were off and I drove it about 15 miles total back and forth to lunch. \
Any Idea's what I should look for? Car just turned 36k on the clock so it's not like it's worn out and my daughter drives like an 80 yr old lady. I have no idea where to look next?
