New car stereo (DUAL) tends to explode...
barney1st
Post by barney1st »
Hi,
I have just installed a new car stereo, Dual brand to replace my dead factory radio in my 2005 Vibe. To install it I have purchased a compatible harness and I have connected the wires myself as well as I could. It works quite great mostly: it replaces the original radio with more features for a fraction of the price! But a disturbing issue happens with it.
Whenever I turn the contact to start the car and the stereo is already turn on, I make a 18 inches jump in my car: a big Boom, sudden crack noise in the speaker for a split second. Great to startle passegers and get rid of your heart-problem in law! Out of that explosion sound, the car radio then turn back on as usual when the car is finally going, as if nothing happened. It basically sounds like a power surge from the contact in the 4 speakers when I start the car, no matter which mode I use on the radio (CD, tuner, IPOD...)
So, using you great common sense and knowledge, where do you think I have screwed up with my wiring? When installing the stereo I was quite confident with all my wiring choices: it was pretty much simply putting together wires that were alike. The only one that made me doubt was the "antenna amplifier", or something like that... can't remembe exactly the name. I believe it was dark blue on the stereo I purchased but was a slightly different color on the Vibe-compatible harness... I connected them nevertheless! :roll:
Any help would be appreciated!
REN69
Re: New car stereo (DUAL) tends to explode...
Post by REN69 »
Mine does that too, and mine is a JVC... Dual is a cheaper brand so it's not the stereo that's the problem, it's the OEM amp picking up noise I believe.
1984 Supra RWD - my beater -- 2004 Vibe AWD - wife's beater -- 2005 Corolla XRS - my daily
barney1st
Post by barney1st »
So there is apparently nothing to do? Is that bad for the radio/speaker when this startling bang happens?
I have no first hand experience with it, but there are a number of threads here where people say they had to install some sort of level converter between the new head unit and the factory amp to eliminate the loud pop you mentioned.
However, you didn't mention if your Vibe had the factory amp, which is an important detail.
barney1st
Post by barney1st »
Sorry for the lack of detail then... I am not sure what is a factory amp, so I guess I don't have one! My 2005 Vibe is a pretty basic model without eletric windows nor electric lock-door! The only fancy option on it is the AC I believe...
