New Touch screen
EVLVibe
New Touch screen
Post by EVLVibe »
Currently looking to replace my stock stero with something a little more flashy...
Had my eye on the Power Acoustik PD-622NB 6.2" INTEQ Double-DIN TFT/LCD Touchscreen Multimedia Receiver. anyone know if there are any issues installing this into my 05 vibe?
Specs:
General
Product Type: DVD receiver
Intended for: Vehicle
Radio
Type: Radio tuner - AM/FM
Total Preset Station Qty: 30
AM Preset Station Qty: 12
FM Preset Station Qty: 18
Connections
Connector Type:
USB ( 4 pin USB Type A ) - front
Composite video/audio input ( mini-phone 3.5 mm ) - front
Composite video/audio input ( RCA phono x 3 ) - rear
Composite video/audio output ( RCA phono x 3 ) - rear
Subwoofer output ( RCA phono ) - rear
Camera connector - rear
System
Form Factor: In-dash unit
Enclosure Type: Double-DIN
Control Features: Touch panel
Features: Rear-facing camera capability, ID3 tags support, iPod/iPhone compatible
Monitor
Type: LCD monitor
Technology: TFT active matrix
Diagonal Size: 6.2"
Resolution: 800 x 480
Analog Video Format: NTSC, PAL
Features: NTSC/PAL auto switching, touch screen
DVD
Type: DVD player
MP3 Playback: Yes
Amplifier
Max Output Power / Channel Qty: 52 Watts x 4
Crossover
Type: Active crossover
Low Pass Frequencies: 160 Hz, 80 Hz, 120 Hz
More Information
Model No.: PD-622NB
Product in Inches (L x W x H): 10.6 x 9.0 x 7.5
ENTER THE GARAGE viewtopic.php?f=30&t=41171" onclick="window.open(this.href);return false;
Re: New Touch screen
Should be pretty straightforward. My son and I installed a JVC DVD radio in his 06 last Christmas and it was pretty easy with the adapter harness, antenna adapter, and faceplate install kit. He soldered all the wires together on the radio harness and the adapter harness and it was basically plug and play. One thing I did do is reuse the metal mounting brackets from the stock radio as they are much more secure than the plastic brackets in the kit. I did have to drill a couple of holes in the metal brackets and cut them a bit to attach them to the new radio. The only part of the faceplate kit we used was the textured radio surround.
EVLVibe
Post by EVLVibe »
looks awesome, im hoping to find a rear usb so i can hide it and set up a small HDD in the glove box to keep mine looking clean but its not easy
wingman7000
Post by wingman7000 »
Just be carefule, my new touch screen (Kenwood DDX770) was stolen within a month. The thieves even broke my passenger window to get it......
http://www.kenwoodusa.com/Car_Entertain ... deo/DDX770" onclick="window.open(this.href);return false;
EVLVibe wrote:looks awesome, im hoping to find a rear usb so i can hide it and set up a small HDD in the glove box to keep mine looking clean but its not easy
Yes, he has a large flash drive (32G?) in his glove box that he has music and movies saved on. The cable is a good 2-3' long so it can be positioned almost anyplace.
