Hey all,
This is my first post on here. I have a 2005 Vibe gt with 103,000 miles. Recently I have noticed a problem with shifting at higher rpms, especially from first to second gear. If I shift at normal rpms the car has no problems but doesn't want to go into second once I am hitting the variable valve. I'm assuming when I try to shift quickly the clutch is not disengaging completely causing it to grind. Any ideas where to start looking for a fix. I'm considering flushing the system and putting new fluid in to see if that helps. Any advice or suggestions are greatly appreciated.
