Transmission problem at high Rpm
05vibegt88
Post by 05vibegt88 »
Hey all,
This is my first post on here. I have a 2005 Vibe gt with 103,000 miles. Recently I have noticed a problem with shifting at higher rpms, especially from first to second gear. If I shift at normal rpms the car has no problems but doesn't want to go into second once I am hitting the variable valve. I'm assuming when I try to shift quickly the clutch is not disengaging completely causing it to grind. Any ideas where to start looking for a fix. I'm considering flushing the system and putting new fluid in to see if that helps. Any advice or suggestions are greatly appreciated.
Re: Transmission problem at high Rpm
If you're lucky, a switch to a quality GL4 fluid will solve the problem.... if not then you have a synchro starting to go.
Certainly change the fluid first. It is a cheap thing to try, and it worked when my Mustang transmission was hard to shift. Hopefully it will work much easier.
Good luck!
05vibegt88
Thanks for the replies. If it is a syncro then it acting different then the one in my 94 saab years ago. That car would actually pop out of gear if I didn't keep force on it. As far as the fluid goes I'm hoping that it is so old that it has just broken down. It is just brake fluid if I remember correctly. The clutch and brake fluid reservoir are all one unit.
This doesn't sound like a clutch problem or master/slave cylinder or line pressure problem.
Transmission fluid. Change it.
Use this: Redline 75W90 GL4
