Fuse and relay diagrams? 1zz vs 2zz
Bad Vibe
Post by Bad Vibe »
looking for differences between 1zz and 2zz relay setups
swapped my spyders 1zz into my vibe gt after pulling the 2zz
can't get it to turn over on any of my 3 1zz ecus
actually turns over on 2zz ecu but won't idle
talked to Monkeywrench racing and they said off the top of their heads that somethin in the area of the efi relay is set up differently either diff wiring or an extra relay
makes sense as it seems to not be getting fuel
please don't flame me for removing 2zz just need info on getting it running :)
03 Vibe GT JDM MR-S 1ZZ-FED swapped w/C60 6 speed - Starting Part out! - 230k mi
90 Celica Alltrac Awd Turbo ST205 swap Red - sold... Buy more parts BC I'm Buying her back!
01 MR2 Spyder Vibe 2ZZ-GE w/ Jdm C65 LSD Trans swap -sold
Re: Fuse and relay diagrams? 1zz vs 2zz
There is a diagram of an 03 Matrix engine control wiring attached to a post in viewtopic.php?t=20326" onclick="window.open(this.href);return false; Shows some differences between 1zz and 2zz wiring, don't know which, if any of them are critical
to me an engine that doesn't turn over is either seized of has bad starter components :)
Bad Vibe
Post by Bad Vibe »
i had a feeling you'd come thru :)
Bad Vibe
Post by Bad Vibe »
do you know where to find the pages the notes refer to?
you can download it from MO's madstyle @ http://madstyle1972.com/2010/12/30/toyo ... -download/" onclick="window.open(this.href);return false;
Bad Vibe
Post by Bad Vibe »
Oh yeah madstyle its all comin back to me lolthx
